Old 09-26-2017, 12:25 AM   #1
Montierth
Montierth's Avatar
Botched C-Notch or OK?
Two owners before me decided to C-notch the frame and looks like they did a botch job! From the pictures do you think the notches are stable enough or would you install a bolt on c-notch kit over what has already been done? After cleaning up the mess, I'm pretty sure I going to install a kit over the mess.
1970 GMC C1500 short fleet
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 1970 GMC C2500 Dually Flat Bed
- 2003 Silverado
Montierth is offline   Reply With Quote
Old 09-26-2017, 12:37 AM   #2
truckster
truckster's Avatar
Re: Botched C-Notch or OK?
All I can say is
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 09-26-2017, 05:02 AM   #3
randy500
That is the worst I have ever seen, I wonder what people are thinking when doing stuff like that. Poor workmanship, poor welds and poor design...
randy500 is offline   Reply With Quote
Old 09-26-2017, 06:27 AM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: Botched C-Notch or OK?
10-20 years ago that's how it was done. There where no kits back then people did what they had to, to get the truck down low. They boxed the frame where they cut it at least. As far as the weld goes it may not look pretty but it's held up and kept the truck together.
They put the stiffeners behind it also.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-26-2017, 06:59 AM   #5
hamjet
hamjet's Avatar
I can't see any strength to it, if you were to jack it at the rear bumper it would probably bend at the area above the c-notch...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 09-26-2017, 08:36 AM   #6
Montierth
Montierth's Avatar
I am hoping that it is not already bent. If it is bent then the cnotch kit probably wont lay very well on the frame.
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 09-28-2017, 04:52 PM   #7
AussieinNC
Moderator
AussieinNC's Avatar
I believe this is the worst case of butchering a chassis C notch on any truck that I have ever seen.
Apart from the total lack of chassis integrity beginning at the forward most part of the cut, the shocks have been pounded on by the chassis edge, making the shocks most likely ineffective, plus angle is just WRONG.
The "reinforcement" plates someone mentioned is doing zero to strengthen the chassis, as the center of the arch is now simply a flat plate, rather than a C channel section.
I believe the only way to correct this is to recreate the side member of the chassis, down to the limit of the notch kits currently available...the outer edge of the current notch piece will need to be cut back to permit the flush mounting and full perimeter weld of the new notch kit.
Once the new kit is in place, a new fish plate style reinforcement plate should be placed on both inner and outer areas of the notch area.
It may actually be simpler to Z cut a new rear chassis section beginning at center cross member, then perform a standard C notch kit install...
Shock relocation and adjustable track bar as standard needs...
UGH UGH UGH
AussieinNC is offline   Reply With Quote
Old 09-28-2017, 11:00 PM   #8
67c10rustbuket
67c10rustbuket's Avatar
The frame gets its strength from the vertical wall of the C channel. There is absolutely zero vertical wall left and about that much strength... like mentioned above all you have is a flat plate. It wouldn't take much of a load hooked on the rear if the truck to bend that frame. You can plate either side all you want, heck even use 1/2" steel, it won't help one bit.
If the frame is straight the way to fix it in my mind would be to install a large step notch and therefore cutting out the old c notch section once welded in place.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 09-29-2017, 12:34 AM   #9
layinrocker65
layinrocker65's Avatar
That's unreal!! Hope you get it fixed for driving it again
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 09-29-2017, 01:16 AM   #10
kwmech
If the frame is not already bent, I would leave it the way it is and smooth the outside of the frame and make an outside piece with a radius in it. Then box the inside of the frame with a matching piece. Is that the brake line being held to the frame with zip ties?
Old 09-29-2017, 10:17 AM   #11
Montierth
Montierth's Avatar
Thanks for all the replies and suggestions. I think the shocks are OK. The angle of the photo is deceiving and the shock is not being hit or binding. I will really have to think this through to reinforce it. It is nuts what you can find on these trucks and what has been done over the years.
Side note. My driver side rocker was replaced and looked good until I took off the front clip and saw they welded on the outer rocker onto rotted front pillar, rear pillar, inner rocker!
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 09-29-2017, 11:43 AM   #12
AussieinNC
Moderator
AussieinNC's Avatar
I believe that "brake line", is actually the fuel line!
Old 09-29-2017, 11:45 AM   #13
AussieinNC
Moderator
AussieinNC's Avatar
The shocks are set at such a huge angle from vertical they would be providing less than 10% of their intended damping action...
I always try and put the shocks as close to vertical as possible...
Is this a short bed or long bed truck?
Old 09-29-2017, 12:15 PM   #14
jeffahart
jeffahart's Avatar
I'm disappointed he didn't notch the axle tubes also. That's the best way to go, notching the axle tubes. You can get super low....
White K20
jeffahart is offline   Reply With Quote
Old 09-29-2017, 01:08 PM   #15
Montierth
Montierth's Avatar
It is a leaf spring GMC short bed. It would be good to find a photo to see how the shocks should be attached stock and then go from there.
HaHa...Good idea with the notched axle tubes. I could also get 13 inch wheels to go even lower!
Yeah the zip ties were a nice touch. It is the brake line. The fuel tank is in the cab so no fuel to back axle. Although by the way some of the things done on this truck maybe it is the fuel line or the flux capacitor!
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 09-29-2017, 01:47 PM   #16
AussieinNC
Moderator
AussieinNC's Avatar
For pics of rear shock locations on leaf spring trucks, use the search capability top of the forum page...choose 67-72chevytrucks.com and the search term
leaf spring rear shocks
There are a multitude of pics available...
I would not be too worried about the shocks until after you correct the "mess" and have a new C notch in place...
Then look at options like Porterbuilt or ECE rear cross member to put both shocks behind the axle in a vertical orientation...or build it yourself...its essentially a single tube with flanges to mount the shocks and the ends to the chassis C section...
Depending on your drop, you may need shorter travel shocks...
Also...suggest you re-position that brake tube to maybe the rear shock cross member if you use one...flex ties were never designed for that use...haha
As this is a leaf spring truck, I can almost guarantee that the rear of the springs is not solid, as it will be flexing and moving up and down with the spring loads...not a nice situation at all...
Stay safe mate
Old 09-30-2017, 09:28 AM   #17
67c10rustbuket
I think your on to something. There's another inch of wasted airspace between the axle shaft and housing.
Dan <---(my name)
