Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-22-2017, 11:12 PM   #1
dustin72
dustin72's Avatar
Rear Anti-Roll Bar Setups
I'm looking for some pics of ARB setups on trailing arm suspensions. I'm running low 11's with 1.5x 60ft's and my launch is pretty twisted even with a 10 point 'cage. Looking at installing an ARB to level my launch. Any particular brands to look at? Thanks.
dustin72 is offline   Reply With Quote
Old 08-23-2017, 01:22 AM   #2
Super73
Super73's Avatar
Re: Rear Anti-Roll Bar Setups
When I had factory truck arms, I made one with:
1 3/4" DOM tubing for the bar
1 3/4" sway bar bushings for an RV
3/16" plate steel as the leverage arms
1/2" rod ends with 3/4" tubing for the links to the frame
It made a huge difference and was cheap.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-26-2017, 11:15 AM   #3
djracer
djracer's Avatar
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-29-2017, 12:18 AM   #4
dustin72
dustin72's Avatar
Originally Posted by djracer View Post
I'm guessing your floor is cut out for that to fit? Looking to keep the stock floor.
Old 09-29-2017, 07:05 AM   #5
djracer
djracer's Avatar
i dont have one because mine is a full Drag truck. that bed floor is super heavy. i have seen anti roll bars done several ways. upside down in cars with stock floors, etc.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 10-11-2017, 05:15 PM   #6
vin63
It's Better With Nitro
vin63's Avatar
I did a through-frame tube crossmember that houses a splined torsion bar for the rear roll/sway bar on my truck. I used some leftover sprint car torsion bar parts since I don't plan to drag race my truck very often. For a drag race truck, I would mount the torsion bar closer to the rearend housing, go with a larger diameter bar, and shorter arms.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
