Re: '60-'66 Body On A '73-'87 Frame
Originally Posted by LostMy65
The point we keep leading back to is; there is no point in using the newer frames. Just use the original frame. There is nothing, absolutely nothing to gain using the newer frames.
If anything, it's bass ackwards to not use the original frame.
Just bolt up the newer crossmember, and be done with it.
Not to mention we should keep the matching VIN's.
What about in the case of an ls swap into a 61? I'm still researching it all
61 apache
