Old 09-27-2017, 09:39 PM   #1
BCOWANWHEELS
need help please
1. going to install a factory front sway bar in a 1970 c/10 truck that never had one, do I have to remove the 2 bottom rivets in the front cross member ...........
2. also I have to replace the entire radio antenna how do I go about this........
thanks for the help
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-28-2017, 12:38 PM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: need help please
Bob, yes you have to drill/grind the two rivets on the front crossmember. As far as the antenna goes, you will have to remove or at least loosen the cowl panel enough to get your arm/hand under there to hold onto/retrieve the aluminum part that keeps the base from turning. See this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=694682
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 09-28-2017, 01:03 PM   #3
BCOWANWHEELS
thanks a bunch................ GOT THE 2 RIVETS OUT........ JUCK WHAT A JOB AND BAR IS FINALLY ON
