75 GMC motirhome TH400 rebuild ?
I have a '75 GMC motorhome and the transmission slips so bad n lost 3rd gear so took it out.
Bought a rebuilt TH400 from an '87 Chev truck but splines are 27 and my original is 32 spline. Is it possible to swap shafts(rear) ? How tricky is it ? |
![]() Join Date: Mar 2003
Re: 75 GMC motirhome TH400 rebuild ?
How did a 27 spline output end up in a 1987 trans? Anyways, it can be done, but both transmissions will have to come completely apart. The output shaft is held into the rear planetary drum with a snap ring. I'm thinking the trans you are looking at is a 700 not a 400
Oh boy. Should run some numbers I guess, not muchto go on.
I'd love to run a 700 in this thing but time n money is an issue. There's alot to convert and I'm not a transmission rebuilder so replacing one just like original seems good if I can find one. |
![]() ![]() Join Date: May 2015
pan I'd
keep in mind ..as it was pointed out in your other post on this ..that most likely in a motorhome its actually a turbo 475.. (or 3l80hd)
Resell the transmission you just bought, and use the money to rebuild the one you were having problems with.
All th400 came with a 32 spline . There is several trany company's making a 27 spline for the 400 . It was so you could adapt the the 27 spline transfer cases to the 400 for a stronger trans ( my guess the 87 was a 4wd , could be a 2wd w/proper tail housing) . This was popular for mud trucks . This trans you have has been modified with the 27 spline or it is not a th400 . It has been apart at some point and possibly with some upgrades for the truck it was used in .
If you are planning to use it one option you have if you know indeed it is a good trans is to change the driveshaft yoke and tail housing ( If needed , depends if they use it on a 4wd ) if the trans shaft is the same length . This may get you by for a while until you have the time to build the original . Yokes are less than a $100 . Last edited by homemade87; 09-29-2017 at 07:21 AM. |
I have looked at the pans - first thing I did, and they are both 400. The shaft lengths are different (I wanted to find a yoke for it)
The fellows I bought the rebuild from were off road truck builders and also said they were initially going to use the rebuild in a hot rod but went with something else. I am listing the rebuild for sale on Kijiji. |
Thanks to all for input and advice !
I am picking up another used that will be nearly identical. I'll hope the rebuild sells soon. |
![]() Join Date: Feb 2004
![]() Join Date: Jan 2002
sometimes the motorhome units had a parking brake on the tail housing??& yes most motor home trannys were thebigger 400 turbos?
I have 86 c10 that came with a 700r4, however those trannys sucked when they first came out mine went out 3 times then i found a kit that you could put a turbo 400 in instead kit had a smaller output shaft to install in the 400 and a shorter tailhousing, so you could just bolt it to your motor and use the factory yoke and driveshaft, you vould have some kind of kit like that in it
there is a th375 model factory with 27 spline shaft . . . not near as common to find .
as others said rebuild the one from your motor home for the best results in the end . a th475 the motor home spec one there is a few major things in there that make them beefy for there heavy duty use .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
