Old 09-28-2017, 01:44 PM   #2226
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Danny Boy is BAACK! w/ '55 Big Window
Thanks NC,
Yeah, I know about pine but I'm using red oak. The boards sat in my garage a couple weeks and when I finally cut the straps you could see its color had changed a little just sitting there. Sanded off easily.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 09-28-2017, 05:48 PM   #2227
Russell Ashley
Russell Ashley's Avatar
"I HOPE there will be room for me to line up the angle strip bolts with the "field" bolts on the strips!"
You can't line up the front one. Because of it's location the nut would show on the outside. The others will be under the fender or in the stake pockets.
Russell Ashley is offline   Reply With Quote
Old 09-28-2017, 07:32 PM   #2228
Dan in Pasadena
Oh, that first bolt would actually be forward of the front stake pocket? Well if so I'll just have to learn to live with imperfection ha ha !!
Old 09-29-2017, 02:27 PM   #2229
Russell Ashley
Dan, this is what I was referring to. The first bolt holding the angle strip to the bed side goes into the stake pocket so the nut is not visible on the outside. The cross sill bolts are about two inches back so the nut on a bolt through the bed side there would show. The others can be aligned with the cross sills.
Old 09-29-2017, 02:36 PM   #2230
Dan in Pasadena
Thanks Russ, yes I understand.
Old 09-29-2017, 07:36 PM   #2231
Dan in Pasadena
Friday, September 29, 2017
Ok, so the truck WOULD HAVE BEEN ready to test drive around the block today except when they went to install the driveshaft it was too long! Mike had sent 3 out for modifiction to a new shop and all of them were too long.
So he read the guy the riot act and it was supposed to be modified and returned by noon today - but it wasn't there by 1pm when I got there.
The only thing it will need after the driveshaft is installed is to put the ignition switch back in the dash and tie up some loose wires that will be terminated later when the bed is installed.
So the journey continues...............
Old 09-29-2017, 11:11 PM   #2232
oldman3
oldman3's Avatar
Sorry buddy on the delay, but you'll get there...Jim
oldman3 is offline   Reply With Quote
Old 09-29-2017, 11:24 PM   #2233
joedoh
joedoh's Avatar
oh man, so close!
Old 09-30-2017, 12:19 PM   #2234
Dan in Pasadena
Hey, does anyone have the link for the aftermarket place that makes the cowl grill delete panel for Task Force trucks? I know I've seen it. Can't recall if it's metal or fiberglas but I'm considering using one afterall.
Old 09-30-2017, 02:26 PM   #2235
G&R's57GMC
G&R's57GMC's Avatar
Brotherstrucks has one cp159sm on sale now $ 79
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 09-30-2017, 04:21 PM   #2236
Dan in Pasadena
Thanks Glen; purchased.
Stopped by the shop today - Trying to keep the pressure on to get the truck delivered. Comes home Mon/Tues til a problem w/spray booth is worked out.
1. Bedsides need 1 more coat of clear on 1 side.
2. Tailgate, front panel & vent delete panel need to be painted.
3. Mount & adjust hood
4. Install all glass
5. Truck to upholstery shop for interior work.
Somewhere in all this the grill, badges, seat belts, tail gate chains, and assorted details will get installed.
At this rate the truck is looking like it'll be a Christmas present to myself.
Old 09-30-2017, 04:55 PM   #2237
G&R's57GMC
G&R's57GMC's Avatar
Hay Dan don't ya love the internet ! Ask , Answer, Get , Post
Glen & Jane's Rides
Old 09-30-2017, 06:39 PM   #2238
Dan in Pasadena
The internet? Mostly yes, occasionally no. It has caused me to spend more money easily than I ever did before!
Summit had the vent panel on eBay for $65.99 with free shipping. Wouldn't have found that price without the interwebs!
Old 09-30-2017, 08:34 PM   #2239
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Let's hope it's an early Christmas present!!
ChuckDriver is offline   Reply With Quote
Old 09-30-2017, 09:36 PM   #2240
Black_Sheep
Black_Sheep's Avatar
Test fit the cowl vent replacement panel before paint, mine needed a little massaging to fit the wiper pivots properly.
Black_Sheep is offline   Reply With Quote
Old 09-30-2017, 09:54 PM   #2241
Dan in Pasadena
Good advice, thanks.
Since I'm switching to this to prevent water, leaves ,etc from entering should I use some kind of gasket? The factory onenever had a gasket. Maybe a bead of silicone-allowed-to-dry first as a gasket?
Old 10-02-2017, 06:34 PM   #2242
Black_Sheep
The edges on the side are just rolled over sheet metal so there isn't really a good surface to seal to. If you are dead set on sealing it, instead of silicone I would use strip caulk because it will remain pliable.
Old 10-03-2017, 02:15 PM   #2243
Dan in Pasadena
I did a bad job of describing what I'm thinking.
1st: I don't think I'll ever turn a hose on the truck or intentionally drive it in serious rain (it' SOCal, "serious rain"? C'mon! lol) So I don't think it will ever see very much water to keep out.
2nd: Like I did on my transmission cover I'd run a heavy bead of silicone on the mating surface and allow it to thoroughly cure. THEN I'd bolt the vent cover down so the silicone acts as a flexible seal or gasket.
Totally agree on "remaining pliable" Using the silicone as a permanent seal would bea cheesy bad idea.
Old 10-03-2017, 05:49 PM   #2244
lower50's
lower50's's Avatar
Well that sucks! But a Christmas present isn't all bad.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 10-03-2017, 06:03 PM   #2245
Dan in Pasadena
Driveshaft is installed. Rear lowering blocks removed - seemed like even with the bed off the rear would be too high.
Cowl vent delete panel arrived today. Looks like a nice piece but I haven't test fit it yet. I'll drop it off with the painter tomorrow. I'd prefer still having the stock vents but w/6-1/2"speakers in the kick panels along with tweeters and possibly AC vents there it would be way too cluttered with the vents on there. Oh well.
PS: Annoying as hell that the pictures rotate. Anyone now a fix?
Old 10-04-2017, 07:53 AM   #2246
Kim57
Kim57's Avatar
Nice looking panel.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-04-2017, 08:15 AM   #2247
bowt1ed
Dan, same one I got from Dynacorn. Fits pretty well, but you may have to massage the mounting holes just a bit to get it to center just right. I tried to find a pic of mine. Good piece.
Cheers, Jim
bowt1ed is offline   Reply With Quote
Old 10-04-2017, 11:54 AM   #2248
Dan in Pasadena
Thanks Jim,
I'll drop the panel off with the painter today and get the latest (as if it'll change!) on when the bed side panel painting will be complete, plus the front panel and tail gate.
Mike texted last night that we'll take a short test drive around the block today. I'm waiting to hear from him, head over to the shop so I can video it. Then I'll flat bed tow it home (9 mi, no glass, no brake lights or door handles, etc) when I'd prefer to drive it on the back roads - then adult thought kicked in and I decided I'd better not - DAMN!
THEN, I'll take the bench seat back to upholsterer and W...A...I...T...!...!
EDIT:
Test drove her down the street 2 blocks. No, forum STILL won't let me load the video!
Runs great. Has a nice low stance but will be adjusted when bed is on. It's quieter (but not quiet) than I thought it would be. Tiny coolant leak to be fixed. Buttonhead Allen screw on Borgeson joint rubs exhaust tubing. Need a 1/8" - 1/4" dimple in exhaust to clear. Brake pedal arm rubs hole in floor, needs adjustment. To be continued...
Old 10-04-2017, 08:04 PM   #2249
Black_Sheep
There will always be things to sort out on a fresh build, thankfully it all sounds like minor stuff.
Old 10-04-2017, 08:59 PM   #2250
ChuckDriver
The first drive is always fun, congrats!!
