Old 09-27-2017, 08:01 PM   #1
hubcaplarry
Question Source for carb part
I am looking for item number 15 in bulk. The Holley ones are paper and good for a couple tightens. I need a correct part number, heard they come in a nylon 10 pack. Some said 510-1008-777 was the correct number. Not certain. I think maybe Midwest fasteners has some in the parts bin or perhaps fastenall or another source. The Carburetor is a 750 #4150.
Thanks in advance!
Hubcaplarry
hubcaplarry is offline   Reply With Quote
Old 09-28-2017, 10:33 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Source for carb part
I used to use the teflon needle seat adjuster nut washers. You can do a search for the teflon washers. I think BLP still sells them in packets and individually.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 09-28-2017, 06:19 PM   #3
hubcaplarry
thanks vin63...ended up at Lowes in the hardware drawer. Nice fit and price.
upper washer
https://www.lowes.com/pd/Hillman-2-C...Washer/3013072
lower washer
https://www.lowes.com/pd/Hillman-5-C...ashers/4635727
$4.00 for several packs!
Hubcaplarry
Old 09-30-2017, 06:05 PM   #4
rvrfoot
Wow lowes had everything.
rvrfoot is offline   Reply With Quote
