Old 09-29-2017, 06:00 PM   #1
Hazieview
Building Dreams out of Dimes!
Has anyone seen a 'cold air intake' style setup ran to the windshield wiper cowl?
I've seen the round air filter housing with a intake duct routed to the front of the engine bay. Has anyone seen an intake duct routed to the windshield wiper cowl? You would have to put a piece of sheet metal under the cowl where the intake duct is routed so that it shields the rain.
Just curious if anyone has ever done it. Not saying I'm going to because I don't see it gaining that much. Just curious...
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 09-29-2017, 07:56 PM   #2
wilkin250r
wilkin250r's Avatar
Re: Has anyone seen a 'cold air intake' style setup ran to the windshield wiper cowl?
Called Cowl Induction, very common in muscle cars, and I believe NASCAR still uses it to this day. At speed, there is a high-pressure zone created at the base of the windshield, so it's theoretically possible to "supercharge" the engine.
In reality, I'd be very surprised if it created more than 2% over atmospheric pressure, and that would only be at high speed, so the supercharging effect is really almost insignificant. BUT, if the ducts are placed right and the airflow path is good, it does guarantee the incoming air is colder than the air under the hood.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 09-29-2017, 09:47 PM   #3
TrailerTrash
TrailerTrash's Avatar
I havent seen it on a squarebody before but cherokee guys do it and they actually make nice kits to do it
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 09-30-2017, 03:21 AM   #4
andrewmp6
http://www.hotrod.com/articles/1301p...ld-air-system/ and close to what most race cars run http://www.fivestarbodies.com/store/...roduct&id=1018
Old 09-30-2017, 06:52 AM   #5
D13
D13's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=741529
Please resist the urge to suck fumes into your cab.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 10-01-2017, 09:08 AM   #6
Hazieview
That's a very good point for those that have an AC or heater. My truck has both the AC and heater Core removed and blocked. Very food point in regards to safety.
SB400 350th
Old 10-02-2017, 03:22 PM   #7
LT7A
Originally Posted by Hazieview View Post
That's a very good point for those that have an AC or heater. My truck has both the AC and heater Core removed and blocked. Very good point in regards to safety.
I read that other thread and don't really see the concern IF, and it's an important if, there is an airbox that is sealed to the firewall. Were someone to cut a hole in the firewall to let cool air in near the carb then there is a high likelihood of contaminating the air that the heater/AC draws from. If the hole is sealed to the airbox/carb, then I could see that some gas fumes could conceivably meander through the air filter, into the cowl trough, and into the cabin. But unless you're running the heater with the engine off, there's not a way to draw contaminated air in. And when both the heater/AC and the engine are running, both are a source of vacuum and have an sizable amount of outside air to draw from based on the size of the plenum.
Old 10-02-2017, 04:36 PM   #8
kacy
kacy's Avatar
The post was removed, OP sent me the info though, my info was wrong from his CAI these were the results.
shows outside temps in the bowl vs up to 100* hotter at 55mph
+0.3 psi in the bowl at 100mph vs -0.1 psi
79 Corvette- 406/7004r Holley EFI
87 V10- 5.7L, Vortec heads, E110026, 410s 35s, 700r4
kacy is offline   Reply With Quote
