Old 04-18-2004, 01:55 AM   #1
dmurphy68
Exclamation 91 K5 blazer for sell w/ pics
91' Chevy K5 blazer 4x4 county/ work truck,
108 k on truck and motor. Has a fuel injected 350, oil has been changed every 3,000 miles with moble 1 synthectic oil and moble 1 filter. Rebuilt 700r4 trans/np transfer case. Body and underneath of truck is in great shape, no rust!! Underneath of truck has been thoroughly pessure washed and spayed with por15 paint and 2 coats of 3m rubberized under coating, looks new and will never rust!! Paint on truck is a 5.5 out of 10! Floor pans have been taking down to bare metal and preped and painted with por15, ready for spray in bed liner, or full interior, will never rust!! Dash,roof and inside of doors are ready for paint. Bottom of both doors and rocker panals have been por15 and ready for final paint. 1/2 of both door jams and tail gate jams have been painted with por15. Back seat is in good shape, drivers seat has a few rips, pass seat is in good shape. Blazer has all new bushings and ball joints in stock front end/with 373 gears. Brand new 33" tires/with 15/10 rims. Blazer is driveable and runs and drives great!! Motor is strong and doesnt burn oil,or smoke!! Blazer comes with a new 10" suspension lift,
8" skyjacker full springs no blocks!! with polyurathan bushing set. 2" traction lift, custon made out of soild steel, painted with por15 and top coat!! 10" skyjacker nitro shocks with boots. 10" stainless steel braided brake lines/ front and rear. Skyjacker transfer case lowering kit. 3" steering block for lift, has been installed with new gaskets.Also have power steering reinforcement plate kit.
Blazer also comes with 1 ton axles,
Dyna 60 front axle with unbrakeable u joints, new warn lock outs, 456 gears/ spider gears have been shimed tight to pull posi in mudd or snow but still streetable!! Everything in axle is new and profesionally installed, brakes, king pins , bearings, and seals, ready for paint.
Corp 14 bolt rear axle, 456 full posi,everthing in axle is new and profesionally installed, brakes, bearing and seals. Have 5 qts of amsoil synthectic gear oil and posi conditioner, axle has been painted with por15 and top coat!! I have everything for lift except for the s link steering linkage, cost $130 new from skyjacker! Have two boxes of por15 paint, top coat, cleaner and metal ready prep. Have all interior parts if not already on blazer. Have K&N filter and new fuel filter already installed. All parts are new and are nothing but the best!!! Blazer has been worked on and stored in a heated garage for the last year!! Selling because no were to keep blazer, and no time to finish it!!! May deliver if not to far!!
For more info call Justin @ 937-855-3205
$6,500 obo Germantown, Ohio
The very atmosphere of firearms everywhere restrains evil interference. When firearms go, all goes, we need them every hour.
- George Washington
No free man shall be debarred the use of arms
- Thomas Jefferson
Later Darren
http://www.myspace.com/dmurphy68
dmurphy68 is offline   Reply With Quote
Old 04-18-2004, 01:58 AM   #2
dmurphy68
lots more I will post a few because it takes too long if interested e-mail me and I will get you more. btw I am selling this for a friend. It is going on e-bay in 4 days but I though you would get a chance first
- George Washington
- Thomas Jefferson
Later Darren
Old 04-18-2004, 01:59 AM   #3
dmurphy68
3
- George Washington
- Thomas Jefferson
Later Darren
Old 04-18-2004, 02:00 AM   #4
dmurphy68
4
- George Washington
- Thomas Jefferson
Later Darren
Old 04-18-2004, 02:00 AM   #5
dmurphy68
5
- George Washington
- Thomas Jefferson
Later Darren
Old 04-18-2004, 02:02 AM   #6
dmurphy68
6
- George Washington
- Thomas Jefferson
Later Darren
Old 04-18-2004, 02:02 AM   #7
dmurphy68
7
- George Washington
- Thomas Jefferson
Later Darren
Old 04-18-2004, 02:03 AM   #8
dmurphy68
last one for now if you want mor e-mail me
- George Washington
- Thomas Jefferson
Later Darren
