#1301 |
Happy to be here
![]() Join Date: Mar 2000
Re: 85 GMC Sierra "Scarlett"
Thanks guys. As always Scot no matter how we try it ends up being last minute
Actually they are on correct. For some reason the stickers are on wrong. Problem reported and resolved.
#1302 |
Looks awesome
#1303 |
Happy to be here
As many of you know, we did make it to Goodguys Lonestar Nationals in Ft Worth to be in the RideTech booth. Of course it was a down to the wire thrash, so allow me to share.
With the rear finished we moved back to the front. One last trip to FedEx had netted the final package with some key components for the front install. Ridetech provides a template to cut the required holes in the crossmember for the coil over shocks to go through but I really wanted to install the mounting brackets first. I bolted the bracket in place, and as I suspected the holes I had drilled to remove the rivets were off. I used the RideTech bracket as a guide to align and drill the holes on center. With that done and bolts installed I scribbed inside the hole to get my cut Mark.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 10-02-2017 at 10:09 AM. |
#1304 |
Happy to be here
There are several ways to make the cut required in the crossmember. The easiest would be with a plasma cutter. I did not have one available so I reverted to plan B and C. I followed the scribbed line with my cut off wheel and considered using it to make the cut.
I soon realized my tool and compressor would have made this a long process so I traced the line deep enough to use as a guide. I tried my sawsall but the width of the blade wouldn't allow tight enough turns so I changed tools again. I have an air powered jig saw that's compact and cuts well. I used the most aggressive blade I had and slowly made the cut. It was time consuming, but much cleaner than the sawsall. I dressed the cut with various flapper discs to ensure no stress point would develop. ***Note the 7/16" x3" bolts that are used to install the upper A arms are pushed in to a hex shaped pocket on the back of the bracket. DO NOT use washers on the head of these bolts.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 10-03-2017 at 09:30 AM. |
#1305 | |
![]() Join Date: Jun 2016
I used a jigsaw with a think metal blade as well. Bubba |
#1306 |
Happy to be here
Bubba I had looked at the template and considered using a 4.5" hole saw. I actually bought one to use. I calcualted the time it would have taken to cut a small piece of wood or sheetmetal to bolt in place to allow for a pilot hole for the hole saw to use as a guide. I still "think" it would have worked, but time was too valuable at this point and I went straight to the tried and true method.
#1307 | |
#1308 |
Happy to be here
I actually considered this myself. You are at the point where its only a few more bolts to drop the entire crossmember. I even have a spare crossmember that made it that much more enticing. In the end, it was a time factor. What could I do in the least amount of time to obtain results that were acceptable to my self proclaimed level of quality.
#1309 |
So let’s see the final stance with the coilovers? Does it sit any lower than before? Any chance to drive it yet to give a review on the ride?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
#1310 |
Happy to be here
Unfortunately I'm not ready to answer yet. We set the coil overs up with an additional 1" preload above -0-. Ironically this gave as an increase in height of 1" from where I was before we started. On the trailer going to FT Worth she settled a 1/2" . We drove her off the trailer and in to the show. With no adjustment on the shocks, and no front end alignment she didnt feel very good. I will elaborate more on the next updates.
#1311 |
Ok thanks!
#1312 |
does the rear sway bar brackets weld to diff housing?
#1313 |
Happy to be here
My pleasure. I promise to give an insightful review once I have enough data. Yes, the only part of this kit that does require welding are the lower mounting points for the rear sway bar. I removed the lower shock mounts attached to the axle for aesthetics, but that is not required.
#1314 |
Happy to be here
With the upper mounting bracket secured in place I was able to start hanging parts. The upper ball joints are bolted to the upper A Arms. The A arms are stamped with a D & P for obvious reasons. Even though they look the same, especially late at night, they must be mounted on the correct side.
With the upper arms in place you can move to the lower A arms. Fortunately the lower ball joints come pressed in place. The factory U bolts are used to mount the lower arms. I bead blasted them to clean up the old threads, then gave them a coat of satin black. I found that the bolts had spread wide and didnt want to fit back in the holes properly. I installed the nuts to protect the threads then gave them a few whacks with a hammer till they fit properly. Also note that the lower arms have a guide pin to align them. Be sure that seated properly while installing the arms.
#1315 |
Looking good Ken!
John J. Sales/Tech Direct Line: 812-481-4737 Office: 812-482-2932 JJohnson@ridetech.com Instagram: @ridetech_john |
#1316 |
Happy to be here
#1317 |
Thumbs up...
#1318 |
Happy to be here
#1319 |
Happy to be here
Chase at RideTech opted to include the new CPP Modular 73-87 C10 2.5" drop spindle upgrade to accommodate the Wilwood D52 calipers that I had previously installed. These spindles are designed to be used with the factory 12" HD rotors and bearings.
I bolted done the adapter bracket that was provided, and mounted the spindles in place. Since Chris was available to help hold things in place, we skipped to the front sway bar. RideTech has updated the Musclebar to a new design. We mounted the end links loosely and slid the bar in place. One end of the bushing clamps lines up with a factory hole and the other needs to be drilled. We tightened everything down and called it a night. The the new MuscleBar requires a shorter version of the factory bushing stands. This kit is a beta version and did not include the stands. Notice that the end links are at an aggressive angle with everything in place and at full droop. We "assumed" that would correct itself when set on the ground. We all know what assuming does.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 10-03-2017 at 09:31 PM. |
#1320 |
Happy to be here
The next morning I finished up the brake install. The recently replaced bearing were repacked, and fresh grease seals were added to ensure that there was no issue with the new spindle. With everything well lubed it was cinched down tight.
With the rotors in place I wiped them down with brake clean to remove any grease residue and installed the Wilwood calipers. They were tightened to specs and the stainless brake lines were routed clear of any obstructions.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 10-03-2017 at 09:44 PM. |
#1321 |
I hate it when there's a echo.
#1322 |
#1323 | |
Happy to be here
Bubba I believe what your seeing is an improper angle dues to the upper A arms being installed backwards. Well, technically not "backwards" just mounted on the wrong side. I discovered this as I was in the process of triple checking all of my work. Laying on my back in the middle of the night, totally exhausted, I wondered why the angles looked all wrong. Thats when I noticed the big D stamped in the passenger side upper arm. To tired to do it again and take fresh pics, I resolved the issue the next morning. ![]()
#1324 | |
Looks sweet tho! Anxious to get details on your ride height and adjustments. Bubba |
#1325 |
Happy to be here
Wednesday night ran in to Thursday morning rather quickly. I was out of time and had to make some executive decisions. I still had not installed the optional front frame braces, or the rear sway bar lower mounts.
I had to repair the rear brake line, adjust the coil overs, install the bed and bolt the wheels on or she wasn't going anywhere. We decided that the damaged brake line took precedence. Unfortunately it fought me with three trips to different auto parts before finally getting a new line and correct fittings to work. With the clock ticking we bled and tested the brake repair and deemed it done. I called my neighbor for help and we got the bed in place. Once more we looked the system over and bolted the wheels back on. She was ready to set on the ground with no time left to install the frame braces. She was as done as she was going to get and still make our deadline to be in Ft. Worth as I had promised.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 10-04-2017 at 09:22 AM. |
