Firewall pad
Wondering if a 71/72 pad is cut out for the cable throttle assembly, anyone have a pic?
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
Re: Firewall pad
I should add I'm installing the later pedal into my '68 to use with the Cummins
Re: Firewall pad
90+ views and no one with a 71/72?
Re: Firewall pad
Interestingly enough, I took a bunch of pictures when deconstructing my truck, but none of the firewall pad itself. I do have some shots of the original pad in the background, when I was taking photos of the electrical wires and stuff under the dash, but I don't know if I got the area you need to see. The pad I have now is an aftermarket re-pop.
Let me know the general area you need to see, and I'll check if I have any pictures that happen to capture that area on the pad.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
#5 | |
Re: Firewall pad
Re: Firewall pad
The triangular piece that the pedal pivots on is bolted over the pad. There are 3 little round holes in the pad for the bolts to go through.
Re: Firewall pad
Right on, thanks for your help! It appeared that way based on the 3 raised holes on the plastic piece.....wanted to do it right the first time!
Re: Firewall pad
Just be sure you get the correct year and you should be good. Only cause 67-68's have the sideways fuse box cutout.
Only problems I had with my 67 was the aftermarket plastic fasteners were way too tight to push through the oe holes, I ordered a set,and the pads came with a set and I ended up using oe rubber ones anyway since I didn't wanna drill
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
