Closed Thread
Old 10-02-2017, 08:49 PM   #5826
Boog
laying low
Boog's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by Ekliptix View Post
Installed new CPP shocks to try to improve the ride over the KYBs included with the ECE drop kit. If this doesn't make me happy, it'll be on to the ultra expensive Ride Tech shocks.
And just in time to put it away for the winter too.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 10-04-2017, 11:55 AM   #5827
Ekliptix
Ekliptix's Avatar
Installed a vacuum reservoir to help the brakes. It didn't seem to help. The brakes have been poor since the 402 with a big cam was installed, compared to the stock 350. Push the pedal hard and takes too long to slow down. Stock vacuum gauge shows 12hg on deceleration but it waivers a lot with throttle position. I hoped the vacuum gauge would be more stable at more then 10hg with this reservoir, but maybe the gauge pickup is on the motor side, not the brake side. I have an expensive Hella electric vacuum pump but was hoping to avoid installing it as a solution.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt.
Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD.
Ekliptix is offline
Old 10-04-2017, 12:42 PM   #5828
BugzC10
BugzC10's Avatar
I added the same one...didn’t really make stopping much different. She stops, but not like I have power brakes. Took it off since it didn’t make a difference
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 10-04-2017, 05:32 PM   #5829
VWNate1
VWNate1's Avatar
Post Vacuum Assist Brakes
Firstly, you need to have a check valve between the engine and the resivoir, since you're never reading above 12" clearly there's a low vacuum issue .
The gauge also needs to be on the booster side of the check valve .
Shouldn't need to add a vacuum pump once everything is properly plumbed up .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 10-04-2017, 05:56 PM   #5830
paul blair
Re: Vacuum Assist Brakes
X 2
paul blair is offline
Old 10-04-2017, 06:04 PM   #5831
Ekliptix
Ekliptix's Avatar
The black plastic cap in the second photo is the 1 way valve. The hose connected to it is from the engine. I blew into it before the install and confirmed the valve worked.
I followed these instructions http://www.jegs.com/InstallationInstructions/200/270/270-99590-1.pdf
Ekliptix is offline
Old 10-04-2017, 06:22 PM   #5832
In The Ten Ring
Got something done today. Removed both battery cables and cleaned those up a bit.
Used Dremel Tool to remove paint and epoxy primer from other ground point on core support.
Ordered two battery clamps from O'Reilly's Auto.
Checked prices on battery cable (4 gauge) at NAPA and Advance Auto.
In The Ten Ring is offline
Old 10-04-2017, 06:48 PM   #5833
chevy2tom
chevy2tom's Avatar
I did the best thing you can do to your truck today......
I drove it!
chevy2tom is offline
Old 10-04-2017, 07:17 PM   #5834
In The Ten Ring
I drove it!
Congrats!
Old 10-05-2017, 10:16 AM   #5835
paul blair
Made some money for a fleet side bed for my K/10 short, by helping a friend with his 70 4x4 BLAZER. Didn't do all this in a day, but it felt good and I am happy with results. New ring gear spacer, bolts Loctite and torqued, shimmed. I know the spacer is not the hot setup but will up grade this winter. New axles, bearings, seals, complete rear brakes and gear oil. Beach ride test run soon! THANKS for all the information and help found here. I believe you can teach a old dog new tricks! Nothin special but here are a few pics. My friend in pic helping with C clips.
Old 10-05-2017, 06:15 PM   #5836
1968aj
Worked on interior a bit . Finally have a radio
1968aj is offline
Old 10-05-2017, 07:08 PM   #5837
In The Ten Ring
I picked up my new battery clamps and then I went to NAPA and they cut new cables for me. I also bought the eyelets, solder, and heat shrinking wrap for the ends. I removed three brackets from Evaporust, rinsed, and hit with rust converter. I then put my last to brackets into Evaporust soak.
Old 10-06-2017, 07:24 AM   #5838
jethro5333
getting ready to do something I was hoping not to have to do. the reman 700r4 I just put in (maybe 80 miles on it ) has to come out and go back to the seller. hasn't worked right since I put it in. and yes the TV cable was adjusted correctly. driving down the road at 60 mph, it will shift down to 3rd and never shift back. doesn't shift to 1st when I come to a stop. just not right. Oh Well.
jethro5333 is offline
Old 10-06-2017, 11:19 PM   #5839
JMC1965
JMC1965's Avatar
Adding this.....because of this....
JMC1965
1967 C20 LWB
  • 350 (ATK-HP32) / FiTech EFI
  • 4L60e / 4 wheel disc brakes
  • 20" American Racing VN327 & 245/50/20 Michelin
JMC1965 is offline
Old 10-07-2017, 07:59 AM   #5840
AussieinNC
Moderator
AussieinNC's Avatar
mmm...is this an auto truck? If it is, I hope you checked that the vacuum modulator on the trans for oil leaks...I have seen a blown modulator suck trans oil straight into an engine, resulting in loads of smoke...just like your pic....
Hope I am wrong...but...
AussieinNC is offline
Old 10-07-2017, 08:39 AM   #5841
JMC1965
JMC1965's Avatar
checked everything...oil fowled plug #8....pulled engine....I'm guessing the PO built himself from a short block. when tearing apart the torque of bolts was all over the map....china wall gasket would have failed soon anyway (inconsistent depth & width).
So....always looking for an excuse for more shiny things....bought an ATK HP32C. Going to pull the carb and re-install my FITech from old motor
Left to right....2,4,6,8.
8 had all the oil on it. Based on 4 & 6 something else was going on also
JMC1965
1967 C20 LWB
JMC1965 is offline
Old 10-07-2017, 08:45 AM   #5842
AussieinNC
Moderator
AussieinNC's Avatar
Ok...sounds like you are on the right track...I would check the modulator anyways...#8 is the cylinder is direct port alignment to factory vacuum fitting for both modualtor and brake booster....
Have fun mate...and you are right...nothing nicer than something new and shiny...glad to see you went Vortec....nice engine!
Old 10-07-2017, 08:51 AM   #5843
JMC1965
JMC1965's Avatar
thanks for the tip on the modulator...will poke around on that too.
yeah....vortec and hydraulic roller cam....looking forward to a little more power
JMC1965
1967 C20 LWB
JMC1965 is offline
Old 10-07-2017, 10:50 AM   #5844
BugzC10
BugzC10's Avatar
Which crate engine did you buy?
BugzC10 is offline
Old 10-07-2017, 12:43 PM   #5845
Tony71c10
Well after a year of having my truck just sitting in the driveway, finally made some progress on it, changed the brake lines, installed Boyds fuel cell, and got The Circle D stall installed, unfortunately after looking at the oil dipstick noticed water in the oil. So now I got to see where its coming from. Got to back to work, so hoping to back at it Wednesday.
Tony71c10 is offline
Old 10-07-2017, 06:26 PM   #5846
Old_Gold
Old_Gold's Avatar
With the help of the forum, I found and installed a set of trash guards under the cowl. Let those leaves start falling!
Old_Gold is offline
Old 10-07-2017, 06:38 PM   #5847
MikeB69C10
MikeB69C10's Avatar
Pulled my step bumper and hitch off and installed this chrome beauty.
MikeB69C10 is offline
Old 10-07-2017, 07:03 PM   #5848
ohboy321
ohboy321's Avatar
I wanted to see if I can get the battery and temp gauges working, so I dug into the wiring to see what I have and don’t have.
Discovered that my dash harness has the wiring for the battery gauge, but the engine harness does not. Not a surprise since the truck is made up from 67, 68 and 70 parts. Can I add the 2 wires to the block on the engine side of the firewall or do I have to run them separately?
The wire for the temp gauge runs into the engine bay, but was disconnected when a PO added the under dash gauges. I should be able to hook that up once I get the correct temp sensor.
These discovery missions seem small, but they are all important as I continue to make the truck better.
ohboy321 is offline
Old 10-07-2017, 08:06 PM   #5849
66clow
66clow's Avatar
Found my intake leak on the 350. Sounds sooo much better. These gaskets seem so cheap.
66clow is offline
Old 10-07-2017, 09:23 PM   #5850
AussieinNC
Moderator
AussieinNC's Avatar
You do mean "my exhaust leak" not"intake leak"...unless you had these exhaust manifold to head gaskets fitted to the intake side!
Have fun mate
Closed Thread
