Closed Thread
Old 10-07-2017, 09:28 PM   #5851
66clow
66clow's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by AussieinNC View Post
You do mean "my exhaust leak" not"intake leak"...unless you had these exhaust manifold to head gaskets fitted to the intake side!
Have fun mate
Lol I'm looking to do my intake gaskets tomorrow so that must have been on my mind lol or I was just testing you all
66clow is offline
Old 10-08-2017, 02:22 AM   #5852
In The Ten Ring
Dad found his impressive cable crimping tool for me and I finished painted 7 pieces for my truck.
Two lower 3 row radiator brackets
Two headlight buckets
Two j-nuts *yes I paint those.
One hood latch support bracket
I have to paint outside and with this rain coming, none too soon!
In The Ten Ring is offline
Old 10-08-2017, 02:53 AM   #5853
KQQL IT
At the body shop.
KQQL IT's Avatar
Because the red ones add horsepower.
KQQL IT is offline
Old 10-08-2017, 12:07 PM   #5854
JMC1965
JMC1965's Avatar
New crate engine... ATK HP32C
http://www.high-performance-engines....hp-p/hp32c.htm
Replaced the carb w/ FITech I had on previous engine
JMC1965
1967 C20 LWB
  • 350 (ATK-HP32) / FiTech EFI
  • 4L60e / 4 wheel disc brakes
  • 20" American Racing VN327 & 245/50/20 Michelin
JMC1965 is offline
Old 10-09-2017, 12:53 PM   #5855
JG358
JG358's Avatar
Cleaned most the junk out of the cab and bed, then loaded it on the trailer for the trip home on Wednesday.
Jake
JG358 is offline
Old 10-09-2017, 04:21 PM   #5856
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today? Chapter II
I bought a push bumper for the RAT!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 10-09-2017, 11:41 PM   #5857
mud.man.rj
mud.man.rj's Avatar
Now that is a bumper, a real bumper of yesteryear, cool.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 10-10-2017, 06:13 AM   #5858
Andy4639
Old member
Andy4639's Avatar
Mudman.
Thanks,
I think it will look great on the Rat!
Andy4639 is offline
Old 10-12-2017, 04:26 PM   #5859
In The Ten Ring
I just came in. I put the newly repainted headlight buckets back on, cleaned the last of the electrical connections, including studs on starter and engine block ground, connected the last two ground wires to the core support, and removed the two front wheels. Yes, my rotors need sanding!
Old 10-12-2017, 04:39 PM   #5860
stevenfromtexas
stevenfromtexas's Avatar
epoxy-ed my ride
Steven
'67 SWB, 250ci, 3OTT.......this is my first build......
I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71"
stevenfromtexas is offline
Old 10-12-2017, 10:39 PM   #5861
In The Ten Ring
I also cleaned up the headlight retaining ring screws with a wire brush and bought some machine screws, washers, and lock nuts (stainless) to mount the front side marker lights. I don't really like J-nuts and I hate pointy screws....you can cut your hand reaching into the fender for something.
Old 10-13-2017, 02:48 PM   #5862
66clow
66clow's Avatar
Pulled intake to replace the gaskets and found this! Does this look factory? should look purty and leak free tomorrow.
66clow is offline
Old 10-13-2017, 03:20 PM   #5863
BugzC10
BugzC10's Avatar
Installed new trailing arm bushings...and new bolts & locking nuts
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 10-13-2017, 03:32 PM   #5864
beaterku
beaterku's Avatar
I started gathering parts for this winters upgrades. They are staring to roll in...
beaterku is offline
Old 10-14-2017, 01:57 AM   #5865
In The Ten Ring
Put the flush-fitting front side marker lenses on with 8-32 stainless steel machine screws, washers, and nylon lock nuts. Not "OEM" but I don't like j-nuts or pointy screws. Seems to be working fine.
Old 10-14-2017, 02:35 AM   #5866
ThePunisher67
Well after 2 months of nothing because My home AC and furnace almost burnt my house down and it cost me 8k to fix. I started buying stuff again Bought a rear fuel tank, New Fuel pump, regulator, Fuel lines New brake lines, New headers for the 382 stroker I bought a few months ago that will go in once the transmission I am buying next month. Hope to buy the New Alternator and power steering pump and Polished chrome pulley's in a week or 2.
ThePunisher67 is offline
Old 10-14-2017, 03:19 PM   #5867
66clow
66clow's Avatar
Finished the intake gasket replacement and did a little painting.
66clow is offline
Old 10-14-2017, 10:29 PM   #5868
KQQL IT
At the body shop.
KQQL IT's Avatar
Hub seals, packed bearings and new pads. Son gets the joy of re torquing the lug nuts.
Bad side of today saw how bad the frame is cracked up by the steering box.
KQQL IT is offline
Old 10-14-2017, 10:35 PM   #5869
projectking
projectking's Avatar
Repaired the engine bay wire harness and dimmer wiring on the '67 custom and drove it.
Installed the front sheetmetal on the '68 Cummins swap for the last time!
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline
Old 10-15-2017, 12:02 AM   #5870
fecklessgadfly
fecklessgadfly's Avatar
Knocked the dirt dauber nests out of the alternator, and sprayed down the wasps that are trying to take over our project.
"Don't get it right. Get it running." -David Freiburger
2014 GMC Terrain I4 (wife's new ride)
2005 Dodge Magnum 3.5 (wife's old ride)
2003 GMC Sierra 5.3 Extended Cab
1972 Chevy Cheyenne 350
fecklessgadfly is offline
Old 10-15-2017, 02:14 AM   #5871
In The Ten Ring
Geeze, and I thought I had it bad!
I reinstalled my headlights and retaining rings. I ended up using two of the original screws but 4 new 3/4 inch machine screws. It was just too hard to get the OEM short ones started. Turns out two of new ones are too long to fit properly so I'll have to get some 1/2 inch ones and try those. It doesn't help that my retaining rings aren't fully round....they've been bent some time before I came to own this truck. Ugh......
Old 10-15-2017, 09:30 AM   #5872
88fordf150
88fordf150's Avatar
Covered my door panels with copies from old drag racing magazines.
Brad handshoe
88fordf150 is offline
Old 10-15-2017, 12:26 PM   #5873
BugzC10
BugzC10's Avatar
Nice touch!
BugzC10 is offline
Old 10-15-2017, 12:55 PM   #5874
mud.man.rj
mud.man.rj's Avatar
Magazines are interesting touch...but don't see any race trucks.
Mudman.
5.0 4spd std.
7" lift w 35's.
Old 10-15-2017, 03:17 PM   #5875
KQQL IT
At the body shop.
KQQL IT's Avatar
Old blue had spider eggs in the caliper pucks.
Yuck
KQQL IT is offline
Closed Thread
