Old 10-07-2017, 09:42 PM   #1
Sweeet67
Bed wood bolts. HELP!
I'm changing out my bed wood, all the small bolts in the field came out fairly easy or broke off. The larger bolt around the perimeter are proving to be a real pail in the a**. Have you guys found a better way? I've sprayed pb blaster, and still no dice. If I'm gonna have to grind or drill all of these, I'm gonna lose it. Thanks in advance.
Sweeet67 is offline   Reply With Quote
Old 10-08-2017, 01:34 AM   #2
Old_Gold
Old_Gold's Avatar
Re: Bed wood bolts. HELP!
If you are changing all the wood, sawsall is the way to go, I had mine out in no time!
Jim
Old_Gold is offline   Reply With Quote
Old 10-08-2017, 03:19 AM   #3
GR8-68
GR8-68's Avatar
Instead of trying to loosen take an air impact or electric and tighten until they snap. This is how I did my stubborn bolts.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 10-08-2017, 03:48 PM   #4
AussieinNC
Moderator
AussieinNC's Avatar
Using a sawsall with a wood blade, cut the wood away a little distance away from the flange, then cut the old wood away from under the flange...
Change the sawsall blade to a metal one and come in from outside into the old wood and cut the bolts off...
Be careful to keep accurate pressure so you dont cut the flanges of the bedside...
Once the wood is out, just cut the bolts in half from under the flange...
AussieinNC is offline   Reply With Quote
Old 10-08-2017, 03:53 PM   #5
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by gr8-68 View Post
instead of trying to loosen take an air impact or electric and tighten until they snap. This is how i did my stubborn bolts.
x2
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-08-2017, 05:04 PM   #6
Sweeet67
I was able to do this with the bolts in the strips. I tried it on the outside bolts, all it did was spin the bolt in the bed side. Which ruined the square hole.
Old 10-08-2017, 05:41 PM   #7
AussieinNC
Moderator
AussieinNC's Avatar
Time for a sawsall then...
harborfreight
https://www.harborfreight.com/power-...saw-61884.html
best $ 30 you will ever spend...just make sure you get wood and metal blades...
