1949 4400 series truck
Anyone know how to get the rear drums off?
![]() ![]() Join Date: May 2015
Re: 1949 4400 series truck
Thanks! It appears from the shop manual that the hub and drum are separate! Really confused me!
![]() Join Date: Sep 2011
Thanks that makes sense! Appreciate the help!
Electrical help!
1953 6400. Power to coil! Power to points. No spark at plugs! New points, condensor, plugs, rotor and cap? |
I had basically the same problem once....turned out to be the condensor...
be just as well to just change it all...points, condensor, rotor button, cap Last edited by mongocanfly; 10-08-2017 at 03:42 PM. |
I failed to mention i replaced the condensor as well?
QUOTE=mongocanfly;8056454]I had basically the same problem once....turned out to be the condensor... be just as well to just change it all...points, condensor, rotor button, cap[/QUOTE] |
I guess I wasn't clear. I put in New points, condensor, rotor and cap.
Also new plugs. I have power to the points. Checked coil it's ok. I'm at a loss? |
check the points, sometimes they short out or have goop on the contacts so they don't actually contact. try turning the dist shaft till the points are open,then, with key on, short the points across with a screw driver. it should spark then. check for spark with the coil wire that goes to the dist normally. I have had trouble with new condensors being no good as well.
on the brake drum, you may have to loosen off the brakes first to get the drum past the shows.
You can connect an ohm meter between the coil - and ground. disconnect the coil + first. Rotate the distributor to check for open/close on the ohm meter. You can crank the engine to get the points just open and have enough wiggle room to rotate the distributor by hand, or place the ohm meter where it is visible through the window to see it while you engage the starter. it should toggle 0v/ovl.
