10-02-2017, 08:30 AM | #1 |
did not think 18 wide tires would fit..they do
I went from 29/15/20 to 29/18/20 and there close..but they fit no problem
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
10-04-2017, 11:38 PM | #2 |
meowMEOWmeowMEOW
Re: did not think 18 wide tires would fit..they do
18" wide rims? Thats gotta be a typo. That would be like a giant construction wheel.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
10-05-2017, 12:39 AM | #3 |
don't know about rims but they defiantly make a tire that wide...uses 15-16" wide wheel..was gonna use these tires (different size) on mine until I read about their lack of traction.....pic loks good...
https://www.summitracing.com/parts/m...MobileSwitchNo |
10-05-2017, 08:07 AM | #4 |
rims are 15 wide, tires are 18.. drives fine don't even know there back there...
10-05-2017, 08:40 AM | #5 |
Well, we need more photos than that!
10-07-2017, 10:57 AM | #6 |
Did you tub it out to get that size tire? If so, how much did you widen the tubs?
10-09-2017, 10:38 AM | #7 |
You will once you encounter any puddle of water. Be careful during any rain showers as well.
