Old 10-09-2017, 04:37 PM   #1
abohler1
abohler1's Avatar
Re: Pinion marks disappeared
So, I have a GM handbook, and it shows the steps without mentioning preload, or removing axels to take the pinion nut and torque to 270 lb ft. I am wondering if this is my best bet as now I cannot confirm the proper placement of the nut from original markings. Thoughts?
Additional Note: If the crush sleeve was originally set to the proper spec, I would assume torquing to the original spec would work.
abohler1 is offline   Reply With Quote
differential, pinion, rear end, seal, torque
