Old 08-29-2017, 02:30 PM   #876
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Knomadd '71 SWB C-10
Coming right along...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 08-31-2017, 02:27 PM   #877
knomadd
knomadd's Avatar
It is and it isn't...
Since Hurricane Harvey is gone and I'm not flooded, I can keep working, but my area is nearly back to normal so I'm back at work. Not a lot of time to figure things out still and I came to a stumbling block this weekend.
I started to put the fenders on and noticed that the top gap to the door was tight while the bottom was MASSIVE! (I know it's sticking out in the pic, but it's really that big when it's tight against the cab.)
I immediately thought it was the core support, but I took measurements of both the old and new and they are identical. I measured from the mount point on the frame to the fender mount.
New, with fender attached:
Old, same location:
I'm using the same bushings, same fenders (inner and outer), cab and doors haven't moved. The only difference is the core support, but the measurements are the same from old to new. I've heard things like I need to replace cab bushings (they're pretty new already) replace core support bushings (I have some and that doesn't make any difference), shim the cab, and just tighten the $hit out of the core support mount to crush the bushings. Everything fit before, so I don't know why this is being so F-ing difficult.
I'm going to try to tighten the heck out of the core support bushings tonight and see if that works. Any other ideas I may need to try?
Oh, and I was curious so I took the core support bushings out all together and the gap is nice (like it was before)... So it's definitely high in front with the bushings in.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 08-31-2017, 10:25 PM   #878
builtbyKane
builtbyKane's Avatar
I have run into the same scenario in 3 situations where I had to pull the core support bushings completely out in order to correct the fender door gap. That was while replacing bushings on cab too. Not sure what's up with that and I have tried a couple brands and all the same results.
builtbyKane is offline   Reply With Quote
Old 08-31-2017, 11:12 PM   #879
Vic1947
Vic1947's Avatar
Originally Posted by knomadd View Post
... I'm going to try to tighten the heck out of the core support bushings tonight and see if that works. Any other ideas I may need to try? Oh, and I was curious so I took the core support bushings out all together and the gap is nice (like it was before)... So it's definitely high in front with the bushings in.
I too ran into issues with the core support bushings. Started out with the "correct" ones for a '67, then went to the later design. Ended up sectioning them to get the height I wanted. If the fender gap looks good with little or no shim in the core support, I'd probably cut down the rubber washer between the core support and the frame and call it good. As far as I can tell, there's nothing sacred about core support bushings other than making sure they don't shift around after finding the sweet spot. I've seen stacks of washers, shims and all manner of evil in there.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 09-01-2017, 04:22 PM   #880
knomadd
knomadd's Avatar
I guess I'll be cutting them down then. I tried to tighten them last night. Used a torque wrench to see just how tight I was getting them and started off with 25 ft-lbs, then 50 ft-lbs and ended up with this... less ugly, but still ugly gap.
I tried to go a little tighter and...
This crap was metric anyway, and I don't like unnecessary metric junk on my classic. The engine and trans stuff is necessary, and expected since it's new, but not a bolt for the core support. I had to use a 17mm and 18mm socket to fit the damn nut and lock nut. No more of that. I'll have to special order 7/16-14 x 3.5" long carriage bolts, but at least it will be correct and not crap.
-Duane
Old 09-06-2017, 02:37 PM   #881
knomadd
knomadd's Avatar
So I got it figured out. The sleeve in the center of the core support bushing was too tall, so I cut it down, and I took about 1/8" off the rubber bushing. It's extremely close, so I let it go and started assembling the front end. To get it perfect, I'd probably need to take off another 1/16-1/8". Here's the sleeve I was referring too:
And now some more visually appealing updates...
-Duane
Old 09-06-2017, 07:24 PM   #882
gringoloco
A guy with a truck
gringoloco's Avatar
Way tall! Wonder what application it's for?
-Chris
Old 10-02-2017, 03:57 PM   #883
knomadd
knomadd's Avatar
Still working on this thing... it's kicking my butt though. Work has been getting in the way, which makes things more difficult, but I think I'm getting close to firing it. I still have some wiring for the fans and A/C (waiting on electrical terminals to custom route my wires), fluids to fill, steam port line to connect to radiator, eLevel ride height sensors to install and connect, and front end to assemble... soon, if I can get the time and motivation (or at least stop being lazy when I get home from work) to get it done.
-Duane
Old 10-02-2017, 04:28 PM   #884
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Your truck is looking so nice! I've had the same issue with that bushing before under the support. What a pita that can be to finally find. Haha
Ryan
1969 Chevy milk truck
Old 10-02-2017, 05:52 PM   #885
Vic1947
Vic1947's Avatar
It looks great, Duane. I like it when a punch list starts to materialize... usually means the beginning of the end!
Victor
Old 10-04-2017, 10:02 AM   #886
knomadd
knomadd's Avatar
Thanks Ryan. It was definitely a pain.
Thanks Vic. The punch list is helping me stay on task and not do things out of order, or at least keep me from doing things that aren't necessary to get the truck inspected and re-registered. My registration expired in December last year, so I have to get that taken care of again before I can drive it.
-Duane
Old 10-06-2017, 02:41 PM   #887
knomadd
knomadd's Avatar
With any luck, I can get the fan wiring done tonight, or tomorrow morning and fire the engine for the first time! I'll take video and post it if I do fire it.
-Duane
Old 10-06-2017, 09:22 PM   #888
Advanced Design
Advanced Design's Avatar
It is coming together very nicely! Looking forward to the start video.
Advanced Design is offline   Reply With Quote
Old 10-07-2017, 10:37 AM   #889
gringoloco
A guy with a truck
gringoloco's Avatar
Getting close!
-Chris
Old 10-09-2017, 06:27 PM   #890
knomadd
knomadd's Avatar
-Duane
Old 10-09-2017, 06:44 PM   #891
Vic1947
Vic1947's Avatar
WooHoo... sounds great, Duane!
Victor
Old 10-09-2017, 08:26 PM   #892
Advanced Design
X2! Nice rumble....
Old 10-09-2017, 09:19 PM   #893
gringoloco
A guy with a truck
gringoloco's Avatar
Woot!
-Chris
Old 10-12-2017, 08:41 AM   #894
mcbassin
Still Learning
mcbassin's Avatar
Awesome work Duane!
Old 10-15-2017, 08:54 PM   #895
ChuckLee
Yah buddy! Love it! I was hoping you would get out and walk around truck while she was running.
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579
ChuckLee is offline   Reply With Quote
Old 10-16-2017, 09:09 AM   #896
knomadd
knomadd's Avatar
Thanks Vic! I'm hoping I can button up a few remaining items this week and get it inspected next week, so I can re-register it before November... We'll see if I can get the time to work on it after work.
Originally Posted by Advanced Design View Post
X2! Nice rumble....
Thanks Doug, I like it! I just hope the interior resonance isn't awful.
Woot!
Originally Posted by mcbassin View Post
Awesome work Duane!
Thanks Mike!
I will Chuck. It will just have to wait until I can pull it out of the garage. There isn't enough room in there to walk around. I have to side-step between the truck and my tool box, step over or around a few things like my welder and engine hoist... I need a shop!
-Duane
Old 10-31-2017, 05:43 PM   #897
knomadd
knomadd's Avatar
Well, I got it outside for the first time in months!
It's up on the jack so I could bleed the power steering / hydroboost system. That didn't go so well... I'm still not done with it. I've done this twice before with an empty (new) hydroboost system and haven't had this much trouble bleeding the system. I guess I'm just being impatient. I'll get the air out, but damn! This is a PITA this time.
-Duane
Old 10-31-2017, 06:39 PM   #898
Vic1947
Vic1947's Avatar
Way to go, Duane! Cool sunvisor...
Victor
Old 11-01-2017, 12:41 AM   #899
Trackman101
Trackman101's Avatar
Where did you source your intake parts? That filter is huge!
Trackman101 is offline   Reply With Quote
Old 11-01-2017, 12:13 PM   #900
OKGMC4
OKGMC4's Avatar
I see the Dapper headlights are in. Have you lit them up yet? How do you like them? Mine have been sitting in the box for months now.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
