Old 10-10-2017, 10:00 PM   #1
Warrens69GMC
Warrens69GMC's Avatar
Re: factory hub caps on 5 lug wheels ?
You should be able to use 1977-1990 Impala 2 or 4-door 15x6 or 15 x7 wheel. Just have to add the clips.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 10-10-2017, 10:30 PM   #2
mongocanfly
mongocanfly's Avatar
that pic of joedohs whitewall tire, wheel, hubcap is spot on..I'm not much of a hubcap fan but if I was going that route that would be it..perfect combo..
Old 10-10-2017, 10:57 PM   #3
joedoh
joedoh's Avatar
Originally Posted by Black_Sheep View Post
they wont work with clip on wheels. I suspect that is what he already has looked at, wheels with nubs and take a 10.5 hubcap.
thats the same wheel as discussed above and I bet the wheel he already has looked at. he could add the clips, but the nubs would stick out, the clip on hubcap is only 7.5" if I remember. the nubs are 10"
By the way, 15x7 5 on 4 3/4 are almost impossible to find on impalas and other big bodies. I only found one set in about a year of scouring yards, and I even used the search at car-part.com I found mine on an 87 olds 98, I looked at about 10 that only had 15x6. buying them from wheel vintiques would have saved a lot of time.
