10-05-2017, 10:34 PM | #1 |
Intake Manifold Gasket Gone Bad Symptoms
Does anyone know the symptoms of a intake manifold gasket going bad
Smoke Tires Not Drugs |
10-05-2017, 11:36 PM | #2 |
Re: Intake Manifold Gasket Gone Bad Symptoms
Lean codes usually will set at idle when cold. Also a high idle speed. They seem to really show up at start up in the morning. What symptoms do you have?
10-05-2017, 11:44 PM | #3 |
10-07-2017, 11:10 AM | #4 |
Lean codes p0300 random misfire code rough idle when cold and so on
10-07-2017, 04:24 PM | #5 |
Runs lean, po300 codes, rough idle almost bad enough to stall, mine got so bad that I heard a whistle.
10-07-2017, 04:28 PM | #6 |
Oil looks like a milkshake from coolant getting mixed in.
2006 Sierra RCSB V6 5 Speed RWD. |
10-10-2017, 10:27 PM | #7 |
If its a ls 4.8 5.3 or 6.0 no coolant though intake
