10-10-2017, 11:29 PM | #1 |
'62 K10 rear shocks: should I stagger/offset them?
Couple things running through my mind about the rear suspension on my '62 K10 project (I can't actually start on it for a while, so I'm brain-building it)
The rear shocks are set up so they limit side-to-side motion (wide at the bottom, meet more in the middle of the cross member at the top). Modern trucks have the rear shocks set up running fore and aft, with a mount on the housing and one shock leaning forward to the frame mount, the other shock leaning backwards to the upper frame mount. This helps combat axle wrap. Has anybody done that conversion to their early K-series trucks? -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
10-11-2017, 06:50 AM | #2 |
Re: '62 K10 rear shocks: should I stagger/offset them?
With a stiff as those springs are I dont think need to worry bout axle wrap.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
10-11-2017, 03:24 PM | #3 | |
GenIII has longer springs on his '63, and said axle-wrap is a bit of a problem for him, so I was wondering if staggering the shocks would solve that. -Brad
10-24-2017, 02:06 PM | #4 |
I had a 60 K10 that had the stock shock locations. Axle wrap was an issue, but because of the 6" tall block between the spring and the top of the axle housing.
I'm not sure if the 62 is the same, but if so, it doesn't matter where your shocks are, you'll get massive axle-wrap with the block. I ended up building ladder bars for mine because I was running 375 HP with a manual and 33" tires. FYI, on the later years with the repositioning of the shocks, the right side of the trucks would always crack the frame and the RR side would sag. I'm sure it is related to the "twisting" action it causes because the shock action would create a twist on the axle housing, rotating the RR rearward more than the left side. (not rotationally about the axle shaft, but about a vertical centerline rotating CW/CCW based on shock resistance.... Hopefully that makes sense....
1970 GMC K2500 Dis-use is harder on a car than mis-use. |
