Old 10-11-2017, 05:53 PM   #9
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Pinion marks disappeared
Did you get a new crush sleeve? The crush sleeve holds a preload on the bearings by collapsing a pre-bent shoulder on the sleeve. So anytime you relieve that preload your supposed to replace that sleeve, that's why you have to re-torque the pinion nut to such a high value. Now with that said, if you re-install the old sleeve like many guys do, you'll tighten that nut until there is no end play in the pinion shaft and give it another half of a hex or 1/12th of a turn. Make sure you use red Loctite on the nut. (I suggest making a holding plate for the yoke and use a cheater pipe to hold it. Use a cheater pipe on a good 1/2" or better yet 3/4" break-over bar to crush the new sleeve to zero endplay and your good.)
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
differential, pinion, rear end, seal, torque
