Old 10-10-2017, 07:35 PM   #1
miller6t9
miller6t9's Avatar
what rotor/caliper do I use with these CPP spindles?
I want to clean up behind these bigger wheels I'm fixin to put on my '72, so I'm thinking about using the Wilwood D52 calipers, hawk pads and whatever rotors will work with these spindles. I cant find the paperwork when I bought them but I think they are the CPP 2.5 drop spindles (not the modular) Am i right? .....and also, I want to be able to use the 15 wheels I have on it now from time to time....so what am I looking for?
miller6t9 is offline   Reply With Quote
Old 10-10-2017, 07:37 PM   #2
demian5
demian5's Avatar
Re: what rotor/caliper do I use with these CPP spindles?
And here my friends is why you want to use a product that uses parts store factory parts.
- I'm sure you can buy them from CPP.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 10-10-2017, 08:04 PM   #3
weq92f
weq92f's Avatar
CPP spindles use proprietary rotors/caliper??? My ECC units use standard off the shelf parts for the application they were purchased for.
Shocker!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 10-10-2017, 08:10 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Your cpp spindles will use stuff right off the shelf as well
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-10-2017, 08:40 PM   #5
miller6t9
miller6t9's Avatar
so its as simple as getting the D52 kit and some 5x5 1.25 inch rotors?
Old 10-10-2017, 08:42 PM   #6
AussieinNC
Moderator
AussieinNC's Avatar
Careful with these...
CP4S4 fits 1973-87 C-10 2” drop $239/pr
http://www.classicperform.com/NewPro...opSpindles.htm
Ball joints and tie rod ends may have different tapers...
CPP correct part number for 71-72 is
CP4S3 fits 1971-72 C-10 2” drop $239/pr
AussieinNC is offline   Reply With Quote
Old 10-10-2017, 08:49 PM   #7
miller6t9
miller6t9's Avatar
I saw that....got curious about it...but they've been on the truck for about 7 years, so who knows.....
Old 10-10-2017, 08:58 PM   #8
AussieinNC
Moderator
AussieinNC's Avatar
It just means someone changed the ball joints and tie rod end to match the larger tapers on the later setups...
They use factory calipers and disc / hub units...if this is a normal driver...stick with stock parts and save the dollars...
Juts make sure you change those rubber brake hoses !
Old 10-10-2017, 08:59 PM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
Yes
71-87 1.25" rotors.
Keith
Convert to disc brakes.
Old 10-10-2017, 09:11 PM   #10
miller6t9
miller6t9's Avatar
quite possibly...heres a pic of the hub that my guy sent to me if this means anything...I think its stock, definitely what was on the truck when i bought it
Old 10-10-2017, 09:12 PM   #11
weq92f
weq92f's Avatar
Good. OP, you're in the same boat as me then... Just purchase rotors and calipers and/or pads for the 71+ model year and they'll bolt right up.
Just like they should ( 40 bucks a side for the rotors and cheap for the rest too ).
-klb
Old 10-10-2017, 09:12 PM   #12
miller6t9
miller6t9's Avatar
Yes
71-87 1.25" rotors.
solid....any suggestions?
Old 10-11-2017, 10:39 AM   #13
weq92f
weq92f's Avatar
Just go to any parts house or online and order the parts for a chevy truck, any year between 1971 and 1987.
Example: 1976 Chevy 1/2 ton truck with a v8 2 wheel drive. That will pull up the correct set of brake parts for your setup ( rotors/pads/calipers/bearings/races ). The choices will be there from the lowest price ( about 40 bucks for a rotor ) all the way up to drilled and slotted, painted hat types for more dollar. You can purchase the standard/stock caliper for cheap or go get the Wilwood equivalent for a bit more, but the parts house year/make/model remains the same: 1976 chevy 1/2 ton 2 wheel drive truck. Typically it will not come up but, if asked, you want the Heavy Duty version which equates to the 1 and a half inch thick rotors.
Hth,
-klb
Old 10-11-2017, 10:46 AM   #14
miller6t9
miller6t9's Avatar
but any suggestions on a particular brand/type of rotors to use?
Old 10-11-2017, 11:00 AM   #15
lolife99
lolife99's Avatar
Personally I like a rotor that is coated from the factory.
Not raw steel.
I've had good luck with SSBC.
Stainless Steel Brake Company.
But for a driver, parts store rotors, with some high heat paint work just fine.
Don't get caught up in all the drilled and slotted stuff, unless you're going with big brakes and calipers.
All those little drilled holes just rust.
Keith
Old 10-11-2017, 12:19 PM   #16
weq92f
weq92f's Avatar
Agree with this ^^^^^^^^^^^^^^. Plus the drilled holes are just for looks anyway and will eventually help kill the rotor over time. Once I put them on all four corners of a daily driver. Will not do it again.
-klb
Old 10-12-2017, 02:14 PM   #17
johnnyburban
You could do zinc plated calipers. This one is from phoenix brake company in Chicago. Here is a pic of their work.
johnnyburban is offline   Reply With Quote
Old 10-12-2017, 08:48 PM   #18
DarkKnightWong
Who cares there products ? Do you have to order direct from them ?
Thanks!
Allen
DarkKnightWong is offline   Reply With Quote
Old 10-12-2017, 09:06 PM   #19
johnnyburban
They are order direct. Their number is 773-277-7772 and website is www.phoenixcaliper.com.
