What back spacing will work?
I looked at some rims today. I will eventually run 33" tires.
1. Would you go 15" or 16" rim? 2. I looked at 16x8 w/4.5" backspacing and 16x10 w/around 4.75" backspacing. Is that too much backspacing? I don't want it to rub on the inside, but would not want too much sticking out the fenders. Any help will be appreciated. |
user # 2756
![]() Join Date: Jun 2001
nope my 35s on 16.5 x 9.75 w/ 4.75 BS don't rub. Go with the 15" rim.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
Geared for Collision
just curious jim why would you say to go with the 15 " wouldnt that mean you have to grind down the calipers? if doing from fresh start why not just go to 16" and skip that step? just curious
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe |
user # 2756
I was assuming 1/2 ton. On a 3/4 ton I'd say 16.5" but that's for the load rating.
