Old 10-09-2017, 12:01 PM   #1
Is this a 3/4ton axel? Don’t know if you can tell from a picture...
Old 10-09-2017, 12:10 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Is this a 3/4ton axel? Don’t know if you can tell from a picture...
not a clue...unless I'm misinformed 1/2 & 3/4 ton axles are the same..only the hub ends are different. .8 lug vs 6 lug
Old 10-09-2017, 12:17 PM   #3
Thanks, that makes sense
Old 10-09-2017, 01:55 PM   #4
sweetk30
sweetk30's Avatar
some had thicker wall tube dia . otherwise yes 1/2 and 3/4 ton use same housing and inner "C" units and knuckles . just brakes and # of lug studs .
that is a early run axle tho with flat top pass side knuckle and upper tie rod style . and the rim/tire combo looks like 37" g/y h1 hummer tires on aluminum rims . this leads me to guess 16.5 8 lug rims . so prob a 3/4 ton 8 lug axle as not many aluminum rims made for 16.5 tires in 5-6 lug .
unless for some crazy chance you can find and read the dana B.O.M # stamped in the axle tube . . . .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-09-2017, 05:57 PM   #5
Exactly why I love this place
68 Chevy diff
Old 10-09-2017, 06:37 PM   #6
kwmech
Actually, it's very possible that it is a 1970 diff being an open knuckle with drum. 68 was still closed knuckle
Old 10-09-2017, 06:50 PM   #7
b454rat
On the other side of the diff where it says 44 there are some numbers/letters. 5,6 and 8 I think. I though it was for literally for 5,6 or 8 lug. But heard somewhere that it's the tube thickness, dunno what they translate to.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 10-10-2017, 01:21 AM   #8
andrewmp6
A picture of the hub sticking out the wheel can tell you also.A dana 60 has huge hubs vs what a dana 44/gm 10bolt used.
Old 10-10-2017, 10:01 AM   #9
sweetk30
sweetk30's Avatar
and our trucks dana 60 stuff was never ball joint and 4 u-bolts . so its not a 60 front . since 60 was king pins and 2 bolts and 3 u-bolts.
and good call on the open knuckle stuff i forgot that .
Old 10-10-2017, 12:23 PM   #10
jeffahart
jeffahart's Avatar
When I looked at the photo the backing plate didn't look good to me. I don't think it's the one year open knuckle, drum. Just because the backing plate looks funky, but then again the pic is a bit fuzzy. Here's a pic of the exact same front left. Open knuckle drum 44. It's an HD, but who cares, 8 lug 1/2" tube or whatever.
I couldn't give the axle away when I swapped. I pulled the ring and pinion and took the rest to scrap.
Anyhow, see the backing plate fits neat into the drum.
White K20
jeffahart is offline   Reply With Quote
Old 10-14-2017, 03:07 AM   #11
andrewmp6
I forgot about the ball joints vs king pins didn't even look at them lol.
