Old 10-13-2017, 05:02 PM   #1
CCCC
CCCC's Avatar
Differences between Edelbrock Performer Intakes
Was fortunate to buy an Edelbrock 3701 for very low dollars, and am wanting to compare it's aspects to a 2701 before putting it to use. Have not been able to find comparative info/specs online. Anyone know about how the 3701 is different from the 2701?
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 10-13-2017, 09:18 PM   #2
Mike C
Mike C's Avatar
Re: Differences between Edelbrock Performer Intakes
Google says the 2701 is the Performer EPS intake and the 3701 is an exhaust gas recirculation (EGR) intake.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-13-2017, 09:27 PM   #3
dflarsen77
Active Member
3701 is also a spread bore flange, so perfect if you have a quadrajet. 2701 has no egr, but it has a squarebore flange, good for holleys and edelbrock carbs.
David Larsen
1970 Chevrolet C-10
dflarsen77 is offline   Reply With Quote
Old 10-14-2017, 03:34 PM   #4
CCCC
CCCC's Avatar
Thanks Mike and dflarsen - it has the spread bore inlet, which is what I need for the Q'jet, and I think I can defeat the the EGR aspect now that I know what it is. Does that sound correct? Thanks for the info.
CCCC
