Could use some help with power brake conversion for 1971
So I have a very bone stock 1971 GMC survivor 1/2 ton. It has front disk/rear drum brakes from factory. It has the proportioning valve from factory.
What is the easiest bolt on solution for me to convert from manual brakes to Power brakes - simply put - who sells the best STOCK power booster conversion that would take the least amount of work to add Power brakes???? Many Many thanks to anyone that would take the time out of their day to reply to this question!!!!!! |
![]() Join Date: Oct 2009
Re: Could use some help with power brake conversion for 1971
The booster is easy, the bracketry is where you have to choose a path and follow it.
You have a few options: 1) Take a look at the parts board and see who is parting out a 71 or 72 C10. Ask for cost of whole power brake setup (brackets, booster, hoses, manifold vac fitting, master cylinder, and lines from the distro block to the frame blocks. Get as much as you can, this will increase the bolt-in aspect). Swap it in. Note the lines from the distro block are further forward, so if you don't grab those, you'll need to bend your own or buy new. They aren't expensive, even pre-bent, so don't worry too much about that. Keep in mind that doing this runs the risk of getting a not-so-new/possibly defective, at the very least "crusty" parts. Parted trucks are just that, and they are usually very crusty - BUT, they are original and correct GM, so perfect for a survivor - you can clean and test the parts as you go, and buy new if needed. So, even if you do this, be prepared to get some new parts. Bottom line, you need firewall booster brackets, pushrods and stuff all the way back to the brake pedal, master cylinder, rod between master and booster, and lines between the master and frame-mounted fuel blocks. I'm probably missing something... I THINK your distrib block will still work correctly because it is disk/drum in 71, but if they'll throw that in, I'd grab it also just in case. 2) do same as above, but JUST get the bracketry and push rods (this way saves money on the initial GM parts buy from a parter outer). Buy a new booster for a 71 C10 and a new master cyl for a 71 C10, and some new distro block to frame lines (or bend your own). 3) buy a booster bracket from member CaptainFab - and take his recommendation for a bolt-on new booster to add to it. You'll need to generate a few custom parts - like tailor your booster pushrod length (I think... might ask the good Captain). His brackets look awesome and tuck the master cyl back onto the firewall, they don't stick out nearly as far as stock bracket system would. 4) Talk to member PICKMUP. Frank puts together some BEAUTIFUL setups - firewall to distro block, all new parts. Worth the very reasonable price and top quality. This may be the least work approach ![]() Couple of notes that can trip you up... - make sure that any master cyl you get is for a C10. C20/30 are designed to have the front/rear reservoirs route to different front/back circuits (if I recall) - master cylinder needs to change - the plunger in the piston (visible from the firewall's perspective) has a different depth hole in it - and the little pushrod between booster and master has to be the correct length. There are two lengths if I recall, one short, one long. Anyway, just make sure they marry up correctly. You'll have questions as you go along - don't hesitate to ask. I've done #2 and #4, happy with both ways. |
Thank you sir.
So my Vacuum would come from the port at the back of my manifold that is capped off before the distributor I presume???
There is normally a small T-fitting or something like that coming out of the manifold between the back of the carb and front of the distributor. Yours may be plugged since it had manual brakes originally. That is the perfect kind of part to grab from a member parting a truck on the parts board.
Post 5 shows the plugged hole in the manifold: http://67-72chevytrucks.com/vboard/s...d.php?t=589077 Summit sells the fittings too: https://www.summitracing.com/search?...cuum%20fitting |
