Old 04-17-2004, 12:59 PM   #1
1971 2wd
Question Rear drum brake problem??
On my 72 1/2 ton blazer dose it have self adjusting rear brake's??
If so how do you make them work agian?
I think the self adjuster needs some kind of lube??
Thanks for any input!!
72 blazer, 71 2wd short bed, 67 nova
Too many damn toys!!
1971 2wd is offline   Reply With Quote
Old 04-17-2004, 01:53 PM   #2
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
I beleive they do. They readust themselves everytime you go in reverse.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 04-18-2004, 08:49 PM   #3
blazerholic
I am a Gov't Mule
blazerholic's Avatar
Last time I did the rear brakes on my K5 the adjusters were frozen with corrosion. After soaking with wd40, I was able to get them apart. Then I put wheel bearing grease on the threads before I reassembled. Works like a charm now.
...to die in the saddle must be my destiny, to ride this rockin' horse I must be crazy...
blazerholic is offline   Reply With Quote
Old 04-18-2004, 11:47 PM   #4
1971 2wd
I'm going try that when I get on the agian.
Thanks for the info!!!!!!!!!
