Old 10-19-2017, 04:29 PM   #1
Hazieview
Building Dreams out of Dimes!
How do you remove the interior fuse block? Fuse holder got pushed out...
Well I got one thing fixed only to have something else fail... Somehow the fuse holder got pushed out of the fuse block for my power windows.
How do I remove the fuse block inside the cab in order to repair the power window fuse holder?
Thanks!
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 10-19-2017, 04:42 PM   #2
mongocanfly
mongocanfly's Avatar
Re: How do you remove the interior fuse block? Fuse holder got pushed out...
if my memeory is right I think there's 2 screws caticornered from each on the block under the dash...then under the hood the other side of the block has one bolt in the center that has to come out
Old 10-19-2017, 05:37 PM   #3
Hazieview
I remember the screw under the hood. I believe it's a 10mm. I'll look again for the screws under the dash. Thank you sir!
SB400 350th
