10-18-2017, 02:26 PM | #1 |
Building Dreams out of Dimes!
When I turn on my headlights my turn signal indicators both come on also...?
Well... When I turn on my headlights both of my green turn signal indicators also turn on. Also when I flip on either turn signal they do not work. With the headlight off everything works fine... Any ideas? It sounds like I have some wires crossed somewhere...
1981 Chevy short/wide. SB400 350th |
10-18-2017, 03:43 PM | #2 |
Re: When I turn on my headlights my turn signal indicators both come on also...?
Check your fuses.
10-18-2017, 04:55 PM | #3 |
It might not be wires crossed, it might be a bad ground connection in your headlight circuit. Just enough to allow low power from your blinkers to work, but the high power from the headlights causes problems.
The analogy would be a slow sink drain. A slow trickle will go down the drain fine, but as soon as you turn your faucet on full blast, it backs up and starts leaking water into other areas.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
10-18-2017, 04:57 PM | #4 |
I would guess that you have a bad ground.
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
10-18-2017, 05:21 PM | #5 |
It means you have a bulb out on the side the signal is pointing
10-18-2017, 06:32 PM | #6 |
That makes since fellas I appreciate it! Hopefully I can find a ground wire unhooked somewhere.
10-18-2017, 06:33 PM | #7 |
All bulbs are working.
10-18-2017, 06:37 PM | #8 |
One more stupid question... Do the parking lights (the ones behind the grille) flash along with the front side markers? It's been so long since I had my truck inspected that I honestly can't remember. Lol
Mine parking lights don't flash... If they are suppose to then maybe I have the wrong bulbs...
10-18-2017, 07:33 PM | #9 | |
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
10-18-2017, 11:10 PM | #10 |
If you put in LED bulbs it can do that.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
10-19-2017, 05:04 AM | #11 |
This is correct, LED bulbs can make all kinds of weird things happen.
10-19-2017, 11:13 AM | #12 |
My turn signal indicators are actually LED bulbs. Perhaps that is my problem...?
10-19-2017, 12:16 PM | #13 |
I ended up changing out my Flasher with a 'LOUD' LF12 Novita Turn Signal Flasher from Autozone. I also found a broken ground wire on the passenger side running light (behind the grille). Thank you guys for all your help. Hoping to get my inspection tomorrow!
1981 Chevy short/wide. SB400 350th Last edited by Hazieview; 10-19-2017 at 04:24 PM. |
10-19-2017, 05:22 PM | #14 |
Whenever I ask for a "loud" flasher the parts guys give me a dumb look. I am going to try that one. thanks.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
10-19-2017, 10:21 PM | #15 |
Hahahahahaha! I believe it!!! I tell you what bud, the 'LOUD' Flasher is the only way to go when you have a loud true duel exhaust. Haha!
