Old 10-20-2017, 06:36 PM   #1
joeydurango
joeydurango's Avatar
Re: Odd tachometer problem - any ideas?
Well, dang it, okay. I'm outnumbered. Easy to re-do the ground wire. I'm just one of those people that really wants to know the "why" of a problem. I would be kind of bummed if a new ground fixed it, and I didn't understand what was going on in the first place.
I'll keep you all posted, for the next guy that has this issue...
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 10-20-2017, 09:21 PM   #2
HO455
HO455's Avatar
To troubleshoot this problem I would let the truck get cold and then put a portable heater in the cab and point the discharge under the dash and get things hot under there and see if the problem disappears. Then you know the basic location of the issue. If it is the cluster and a ground wire fixes the problem most likely the screws that hold the cluster together have gotten loose and when the parts get warm they move slightly and the ground is restored. This is a milliamp circuit so it doesn't take much resistance to alter readout. If the heater or ground wire trick doesn't help then I would disconnect the factory tach lead at the coil and the guage and run a separate test wire through a window and see if it makes the tach work correctly. Another easy check would be to swap the HEI cap and coil with another one. Somewhere you have a spot that is not conducting until it warm. The gap is closed by the themal expansion of the components.
RIP Bob Parks.
