Old 10-20-2017, 09:25 PM   #1
BCOWANWHEELS
How to polish some parts
How do you fellas polish the front grill aluminum surround .
Also how do you polish gauge cluster lens.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 10-20-2017, 11:06 PM   #2
hotdog hound
Re: How to polish some parts
Never Dull on the Chrome, Stainless, and Aluminum and Toothpaste on the glass
hotdog hound is offline   Reply With Quote
Old 10-21-2017, 12:10 AM   #3
toolboxchev
I did an experiment on my old dented up and rusty stuff.
Flitz
It did quite well. I have tried never dull, works, yet the flitz removes oxidation more readily. less work 4 me!
toolboxchev is offline   Reply With Quote
Old 10-21-2017, 03:11 AM   #4
BCOWANWHEELS
by hand
Old 10-21-2017, 05:24 AM   #5
rockyrivermark
Mothers aluminum and mag polish is amazing stuff!
Little elbow grease needed with great results
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 10-21-2017, 11:14 AM   #6
First thing you do to polish an aluminum grille is remove the anodizing, then bring back the polish.
Old 10-21-2017, 12:08 PM   #7
BCOWANWHEELS
how do you remove the anodizing
Old 10-21-2017, 08:07 PM   #8
In The Ten Ring
I went through this a couple of years ago. I took mine to a media blaster in Maryland. It's super shiny now and I haven't polished it in two years. It's been inside that entire time though.
After you get it blasted, scuff up the areas necessary with a scotbrite pad (those areas are year specific), tape off, and spray paint satin black. That was factory.
The blaster suggested Wenol as a polish.
In The Ten Ring is offline   Reply With Quote
Old 10-21-2017, 10:48 PM   #9
toolboxchev
Some say to use that cheap oven cleaner at Dollars Stores, it strips it right off. I have a couple pieces I am going to run an experiment on.
Old 10-21-2017, 11:44 PM   #10
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Sounds like it's common practice not to re-anodize the grille again. That true?
I heard that oven cleaner strips it right off. If I recall, the same for paint on plastic.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 10-22-2017, 04:04 AM   #11
Cbo
What the name of the oven cleaner you guys are using?
Cbo is offline   Reply With Quote
Old 10-22-2017, 09:12 AM   #12
rockyrivermark
Here's what did and got great results.
Buy some hair and grease remover. It's a drain opener and you can get it from a Home Depot or Lowe's etc.
wear gloves and eye protection.
Apply the remover and let sit for 5 min. Then use scotch brite to scrub off the anodizing. The grille will then look dull silver.
Then sand the entire grille in an order similar to this.
220 grit
320
400
600
800
1200 wet sand
2000 wet sand
Polish with mothers aluminum and mag polish
Clean with denatured alcohol
Seal with permaclear sealer
Takes a Saturday afternoon
But looks great and never needs re polishing since it's sealed.
My build page
Old 10-22-2017, 09:18 AM   #13
rockyrivermark
Pics
My build page
Old 10-22-2017, 10:08 AM   #14
my56chevytruck
my56chevytruck's Avatar
I've used Adam's polish for years, found it to be the best. The sheen lasts for a very long time.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 10-22-2017, 01:06 PM   #15
BCOWANWHEELS
whats permaclear
Old 10-22-2017, 09:55 PM   #16
rockyrivermark
whats permaclear
I searched this board this past summer looking for something to seal the aluminum since I was polishing every other week. Didn't have any luck and searched the web and finally found this
Perameal.
It's a thin sealant so far works great. Manuafactured for commercial aluminum store front doors, hardware etc.
google is.
$20.
My build page
Old 10-23-2017, 12:00 PM   #17
DT1
DT1's Avatar
I've done a couple of them before. The picture is from an old post. I stripped the anodizing with a 20:1 mix of cold water sodium hydroxide. It's very caustic and will strip it off in minutes.
DT1 is offline   Reply With Quote
