Old 10-22-2017, 01:07 AM   #1
JQ-72
JQ-72's Avatar
Stock 350 casting question - 010 vs 014
I've got 2 stock 350 engines that were cast 5 days apart at the same engine plant, but they have different casting numbers. Wondering what the difference was. Here the info:
1) - 1972 GMC 1/2 ton. Suffix V0425TDJ. Casting 3970014
2) - 1972 Chevy 1/2 ton. Suffix V0420TDJ. Casting 3970010
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track
72 Cheyenne Super swb. 350/350 A/C, bucket seats
72 Cheyenne swb. Factory 402/400, tilt, posi, A/C
72 Cheyenne Super K-10. 350/4 spd., posi.
72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack
72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior
JQ-72 is offline   Reply With Quote
Old 10-23-2017, 12:00 AM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Stock 350 casting question - 010 vs 014
In my experience, all 014 blocks I've had were 2 bolts and had staggered 2 bolt starter pattern, and I have 010's that were 2 and 4 bolt, and had straight across or staggered starter patterns.
I had a 014 block that I built to replace an engine in my Camaro years ago, and my straight pattern mini starter wouldn't work with it.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 10-23-2017, 05:07 AM   #3
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I'll let you look up the casting numbers but they are both essentially the same block with the 010 casting running from 69 - 79 and the 014 ran only from 70 - 73
V0425TDJ V= Flint 04= April 25= 25th day TDJ= TDJ 1972 350 conv.cab,a/t 175 4 C-10 & 20
TDJ 1980 350 van & bus,a/t L LS9 155 4 C-10 to 2500
http://www.nastyz28.com/sbchevy/sblock.html
http://www.nastyz28.com/gm-chevy-cod...s-suffix-7.php
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 10-23-2017, 05:09 AM   #4
JQ-72
JQ-72's Avatar
I've already got the 014 engine torn down and it's a 4 bolt main with staggered starter holes.
Old 10-23-2017, 06:29 AM   #5
Ironangel
Ironangel's Avatar
They came with 2-bolt mains as well. It depended on the application, 3/4 ton van and truck almost always got the 4-bolt while the 1/2 ton applications usually did not. Some of those 041 blocks were used in the Z28's and Corvettes as well...The same can be said for the 010 as well, they came in both 2 and 4 bolt versions picking up where the 041's stopped in 73.
"Two Seventy Two's"
02 3/4 ton Express
Old 10-23-2017, 08:39 AM   #6
010 blocks were used in '68 for sure. It is the casting used for the '68 Camaro SS350 and the Z/28 302. Mine is a large journal 327 from a '68 C/20. I always believed the 010 to be the first large journal small block casting.
Old 10-23-2017, 10:06 AM   #7
geezer#99
geezer#99's Avatar
The suffix code doesn't show the cast date of the blocks, it shows the date they where installed in the truck.
Either one or both could of sat waiting to be used for 6 months or more.
geezer#99 is online now   Reply With Quote
Old 10-23-2017, 01:59 PM   #8
JQ-72
JQ-72's Avatar
Oddly enough, blocks were cast 5 days apart - D 14 72 and D 19 72. Just wondering if one being a GMC had anything to do with it.
JQ
Old 10-23-2017, 02:21 PM   #9
Jcfcamaro
Jcfcamaro's Avatar
A machine shop guy told me the 010 blocks were really good because they had a higher nickel level in the casting which made them stronger.
Jcfcamaro is offline   Reply With Quote
