Old 10-26-2017, 08:57 AM   #1
old51sedan
old51sedan's Avatar
Re: 292 carb heat
Originally Posted by jimelfarm View Post
Your right,the exhaust heat would be much better if you can get enough through the small copper lines. How did you fasten the copper lines to the exhaust manifolds?
That's the problem with the Langston headers. The Fenton & Williams headers both are drilled and taped for lines. I just ran copper lines one from each header to a plate under the carb, works great. Name:  IMG_0128.jpg
hope this works
old51sedan is offline   Reply With Quote
