Old 10-28-2017, 10:04 PM   #1
DT1
DT1's Avatar
LMC Carpet Way Too Long (What to Do?)
I'm putting the carpet in the 72 and it's at least 10 inches too long. I pushed it up on the firewall as far as it needs to be and it still covers the gas tank by 10 inches. The carpet in my 71 is seamed right at the base of the tank, so I know this is not right. Should I cut this carpet or unbolt the tank and slip it under? If I cut it, what should I use to seal the edge to keep it from fraying? This kind of makes sense in that what ever I get from LMC is always too long or too short or doesn't fit at all. Not ranting but LMC is about as sub-standard as they come. I blame myself for continuing to use them.
DT1 is offline   Reply With Quote
Old 10-28-2017, 11:46 PM   #2
1968aj
Re: LMC Carpet Way Too Long (What to Do?)
cut it off and make some door panel or kick panel inserts
1968aj is offline   Reply With Quote
Old 10-29-2017, 12:21 AM   #3
Jcfcamaro
Jcfcamaro's Avatar
Don't they offer 2 different ones? One with gas tank in cab and without gas tank.
Jcfcamaro is offline   Reply With Quote
Old 10-29-2017, 04:28 PM   #4
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Yes they do and I think they may have shipped the poster the wrong one.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 10-30-2017, 08:33 AM   #5
DT1
DT1's Avatar
That's probably it. Too Much to return it so I cut it and re-seamed. Too bad after all these years LMC still can't get there stuff together. I would love to cut them loose but they seem to have a much larger selection of the small stuff. In the future I will avoid LMC as much as possible.
