Old 10-28-2017, 09:47 PM   #1
57rookie
Exhaust diameter for a 71 stock GMC
I am looking to see what the stock diameter ( the diameter that the muffler manufactures want, not sure if ID or OD) for a bone stock 1971 GMC with a 350 and a 4BBL carb. I dont have the measuring tool to clamp on and find the diameter.... My best guess is 2.5#. Looking to see what you experts know.
Thanks!!!!!!
57rookie is offline   Reply With Quote
Old 10-28-2017, 11:51 PM   #2
Husker
Husker's Avatar
Re: Exhaust diameter for a 71 stock GMC
2 inch
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 10-29-2017, 01:15 PM   #3
57rookie
the circumference is 7.5" around using a piece of tape. I am having a brain fart here - there was a formula posted using pie 3.14 to tell me the diameter - anyone have this formula???
Old 10-29-2017, 01:24 PM   #4
racerop
racerop's Avatar
C=πd
Pie=π
C=circumference
d=diameter
racerop is offline   Reply With Quote
Old 10-29-2017, 01:27 PM   #5
57rookie
So I figured it out. I re measured using piece of tape and it is actually 7.75" in circumference. Then you calculate and it came out to 2.468" diameter so my factory exhaust at the inlet of the single muffler is 2.5". I knew it looked larger than 2". The tail pipe is 2".
Old 10-29-2017, 01:37 PM   #6
Leonard60
Pipe is measured by nominal inside dimension. So 2" pipe would be larger that 2" on the outside. The inside of your pipe is likely what you call 2".
If you don't have a vernier caliper you can use 2 squares to measure the out side of your pipe then use the formula Pi X d and that will give you the out side diameter. This measurement only gives yo outside diameter not the tru pipe size.
Leonard60 is offline   Reply With Quote
Old 10-29-2017, 01:55 PM   #7
Leonard60
I wrote down diameter not circumference my mistake. Diameter is Pi divided by circumference
Old 10-29-2017, 06:05 PM   #8
71cheyennesuperlongb
71cheyennesuperlongb's Avatar
Pipe is measured I.D. Tubing such as exhaust ismeasured by theO.D. Retired pipefitter of 40 years.
'71 Cheyenne Super LWB - Second Owner in 39 Years!
'70 CST/10 SWB - Soon to be Daughter's truck when finished
71cheyennesuperlongb is offline   Reply With Quote
Old 10-29-2017, 06:21 PM   #9
Husker
Husker's Avatar
2 inch inside. If your tailpipe is 2 then wouldn't that be the overall diameter.
It would restrict down to tailpipe. Just Askin.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 10-29-2017, 07:13 PM   #10
Killer Bee
Killer Bee's Avatar
this should clear things up a bit without getting too far off into the weeds..
How to Measure Exhaust Pipe
simple tape measure is all you really need to measure common exhaust tubing unless you need to measure a section without access to an open end then a cheap dial caliper is sufficient as long as the jaws are deep enough..
here's a quick chart to get you in the ball park based on engine output..
good luck!
Old 10-30-2017, 02:29 AM   #11
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Gospel truth. Short answer is; 2" You'd be surprised how many engineers don't know the difference between pipe and tubing...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
