10-28-2017, 05:56 AM | #1 |
noticed th350 slipping
my c20 th350 recently began slipping, have only noticed slip in first and reverse. am generally happy with th350 if I stick with it and rebuild, is it possible to have final third gear changed from 1.0 to say 0.90 ? running 4.1 rear gear but planning on changing that at some point.
10-28-2017, 07:39 AM | #2 |
Re: noticed th350 slipping
Not possible. The unit is designed to run at 1:1 final drive. Not as simple as a gear change in a manual transmission. Even if you could, you would only have three gears and sacrifice 3rd.
I assume your fluid is topped off and it still slips. Does the fluid look burnt?
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-30-2017 at 07:51 AM. |
10-28-2017, 07:55 AM | #3 | |
**RED SEAL CERTIFIED JOURNEYMAN SINCE 1993** My 1966 GMC Value Van Project 1951 GMC 9430 1-Ton I'm just going to put an OUT-OF-ORDER sign on my forehead... and call it a day. |
10-29-2017, 05:28 PM | #4 |
3rd "gear" has no reduction, the power is transmitted at a 1:1 ratio straight through to the output shaft. Overdrive transmissions have another gearset for the task.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
10-29-2017, 07:09 PM | #5 |
Moderator
Look into putting a 200R4 into the truck...same length as a T350...has overdrive...and can be built pretty stout ,...
Just my two cents worth |
10-29-2017, 07:11 PM | #6 |
Nothing in common with first and reverse. It would be strange to have those symptoms in common.
The gear set turns as a locked unit in third so no way to get an overdrive ratio
