Closed Thread
Old 10-24-2017, 08:26 PM   #5926
paul blair
Re: P.S. Hose Service
Thanks Nate for the advise! Just received a new pressure line from Summit and it has male fittings on both ends--the one I removed has a female fitting on the pump end. I searched around and found GATES #14158-05283370 has a female end for the male pressure port on the pump. Might check NAPA. SUMMIT only listed one for 69-70 K/10--I wonder if I might have a 68 pump or one from a car or if EDELMANN hoses made in MEXICO installed the wrong fitting. Thanks for the filter idea.
paul blair is offline
Old 10-24-2017, 08:48 PM   #5927
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
Before anything else look at the pictures of P.S. hoses on Rockauto.com to see of mayhap they sent you the wrong one ~ it happens, I have the decades of stories to back that up .
I have worked on an old truck once or twice .
I forget where I bought the new P.S. hose for my '69 C.10, maybe NAPA ? they too will have a picture but usually only _one_ to choose from .
Filters are always a good idea on older rigs ~ I retain them as I flush any system until the ATF remains translucent and sweet smelling, then I discard them .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 10-24-2017, 08:56 PM   #5928
paul blair
I just found the NAPA filter, think I will get one-good idea! Happy Trails
Old 10-24-2017, 10:40 PM   #5929
57rookie
I adjusted my quadrajet thanks to Geezer for the help. Also installed fuel filter and some vacuum hose. Tomorrow I will install an HEI distributor and wires hopefully!!!!!!z
57rookie is offline
Old 10-24-2017, 11:19 PM   #5930
Hotcorner
Hotcorner's Avatar
Rehabbed my Unity spotlight
1969 GMC K25
2007 Chevy 2500HD Classic Duramax
1999 Tahoe 2DR 4WD Base Model 5.7l
Hotcorner is offline
Old 10-25-2017, 07:27 PM   #5931
VWNate1
VWNate1's Avatar
Question Unity Spotlights
? Is there any place that still sells the correct white handles ? .
TIA,
-Nate
Geezer
VWNate1 is offline
Old 10-25-2017, 08:50 PM   #5932
KY_GMC
KY_GMC's Avatar
Finished the trim and installed it on the truck.
1972 GMC 1500 Super Custom, 383 Stoker, TH350
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592157
Engine Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592233
KY_GMC is offline
Old 10-25-2017, 08:59 PM   #5933
Hotcorner
Hotcorner's Avatar
TIA,
http://www.unityusa.com/U-6450-Ivory...rip_p_592.html
My handle grip is black, FWIW.
Old 10-25-2017, 09:30 PM   #5934
mud.man.rj
mud.man.rj's Avatar
KY_GMC the trim really looks good with the rim colour, nice job.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 10-25-2017, 09:40 PM   #5935
Duck 37
Smile Re: What did you do to your truck today? Chapter II
Still on lwb to swb project. Only have a few hours each day. 72 frames are a little different so there where some questions that needed answered, Jamie at Brothers took care of that and now should be able to go back together as soon as I get the rear frame cleaned and painted
Duck 37 is offline
Old 10-26-2017, 04:45 PM   #5936
jojomiamia
Nothing,
Camshaft received broken from Summit (ship to France) no bubble wrap at all, I am curious how it can be possible to gamble at that point.
Anyway, after a quick chat, they’ve sent me a new one
jojomiamia is offline
Old 10-27-2017, 10:47 AM   #5937
Daniel67
Daniel67's Avatar
Cleaned up my fan today. Still have to paint though.
Daniel67 is offline
Old 10-28-2017, 03:30 AM   #5938
In The Ten Ring
I bought more hoses and figured out how I am going (I think) to fix my radiator hose problem long term and get the engine running short term.
In The Ten Ring is offline
Old 10-28-2017, 01:40 PM   #5939
VWNate1
VWNate1's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
THANK YOU ! .
It's good to know they're available again .
FWIW, yours would have been white when new .
I saved quite a few off 1970's vintage Police / Govt. vehicles but all were used over the years .
-Nate
Geezer
VWNate1 is offline
Old 10-28-2017, 10:57 PM   #5940
paul blair
VWNate1, I took Your advise and installed a P/S filter with the new pressure line. Had to remove inner fender to install the new line because of higher profile. Was easy once the inner fender was out of the way. Test run tomorrow! Thanks again for Your information!
Old 10-29-2017, 01:41 AM   #5941
dflarsen77
Active Member
I scraped the quarter inch thick layer of oily dirt off the front of the frame, sprayed it in simple green, then pressure washed it. Man what a disaster. It's a lot cleaner tho...
David Larsen
1970 Chevrolet C-10
dflarsen77 is offline
Old 10-29-2017, 01:49 AM   #5942
KQQL IT
At the body shop.
KQQL IT's Avatar
Washed Old blue and went to the trunk or treat.
KQQL IT is offline
Old 10-29-2017, 02:40 AM   #5943
In The Ten Ring
Hooked up last of the radiator hoses. Bought distilled water and concentrated antifreeze. Ordered a new gasket set. Installed gasket under water neck. Bought and installed new air filter.
Can you guess what I am about to do?
Old 10-29-2017, 11:53 PM   #5944
Gobuffalo
Gobuffalo's Avatar
Built and installed an enclosed air cleaner box / computer box.
Gobuffalo is offline
Old 10-30-2017, 09:33 AM   #5945
66clow
66clow's Avatar
What did you wash your truck with to make it look like the bottom truck? great before and after wash
66clow is offline
Old 10-30-2017, 01:04 PM   #5946
OregonNed
OregonNed's Avatar
I'd never really bothered to look, but I needed fuel this last weekend, and instead of using the regular non-leaded and stabil, I found a station a couple of miles away that vends super non-ethanol, 92 octane - so I know where I will be going from now on. Decided to throw in a can of Seafoam for stabilizer over the fall and winter, but I do start and warm it up every week or so - and on dry days take it for a spin..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 10-30-2017, 01:44 PM   #5947
Coley
Coley's Avatar
....ahh, did my oil change....and added a little MMO in there.
Just nice to do in a way....and always good piece of mind knowing its clean again.
Now......time to start getting ready to find a good 'paint' partner and bring some of the other parts of the truck up to scratch.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline
Old 10-30-2017, 02:07 PM   #5948
Boog
laying low
Boog's Avatar
I want some of what he’s using!
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 10-30-2017, 07:43 PM   #5949
Possmguts
Possmguts's Avatar
Originally Posted by GR8-68 View Post
I did a lot !!!
What did I miss here? Did you start on another one??
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 10-30-2017, 07:50 PM   #5950
bennylava
bennylava's Avatar
I stared at it in shame!
bennylava is offline
Closed Thread
