Old 10-28-2017, 09:13 PM   #1
Bandit130
Bandit130's Avatar
Timing Issue.....I think.
74 C10 350 TH350. Stock (original) engine. Upgraded OEM points distributor to HEI. I removed coil, cap and wires. Turned harmonic balancer mark to 0. Checked where rotor was pointing before removing old dist. It was pointing to #6 plug. From info I have found, it should point to #1. Installed HEI and set rotor to point to #1 and would hardly run with dist turned all way counter clockwise. Is this a timing issue with cam and crank?
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 10-28-2017, 09:37 PM   #2
Gixx
Re: Timing Issue.....I think.
OK, with the timing mark at zero on the scale, The rotor can either point to number 6 or number 1. One is TDC exhaust and one intake.
Either way,
It sounds like you are 180 degrees out on your rotor. So, I'd suggest pulling the distributor up about an inch or so and rotate the rotor 180 degrees and then drop it back in.
THEN set timing with a timing light. That sould get you running again.
Gixx is offline   Reply With Quote
Old 10-28-2017, 09:54 PM   #3
Bandit130
Bandit130's Avatar
So, If I reset dist to point at #6 as the old one was, and mark at 0, It should be ok? Then set with timing light?
Mopar by Birth
Chevy by Choice
Old 10-28-2017, 09:55 PM   #4
Gixx
Yeah, that should do it !
Old 10-28-2017, 09:58 PM   #5
Bandit130
Bandit130's Avatar
Very good. Thank you so much. I may have not understood the info I found.
Mopar by Birth
Chevy by Choice
Old 10-28-2017, 10:01 PM   #6
Gixx
Well, Its a little confusing, because you would THINK that if the mark was at zero, ten the rotor has to point at #1, but it can also point at #6, depending on where it is in the cycle.
You just got "lucky" and it was on #6, and you thought it should be #1, so you put it in that way.
Old 10-29-2017, 06:22 AM   #7
cadillac_al
Whenever i swap distributors I point the rotor at the firewall and reinstall the new one the same way. You can't mess it up that way. It sounds like you are off one tooth since it runs; you just don't have enough timing adjustment.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-29-2017, 11:08 AM   #8
rwhit57
rwhit57's Avatar
You should probably just start over. With the distributor out and #1 spark plug out you can have someone bump the starter until you feel the air or compression from the spark plug hole, stop and by hand set the timing mark TDC. Then drop the distributor in pointing at #1 wire. Then you can adjust it from there.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 10-29-2017, 04:08 PM   #9
Dead Parrot
If you haven't pulled the distributor yet, you can just put the #1 wire on the post currently holding #6 and just follow the firing order around. The distributor doesn't care which post is #1. If it then runs like it should, you can decide if you want to pull and re-stab the dizzy so that #1 post is in the traditional place and reset all the wires.
Dead Parrot is offline   Reply With Quote
Old 10-29-2017, 04:58 PM   #10
Killer Bee
Killer Bee's Avatar
bingo! my advice as well, static time for 0 and proceed from there..
eliminate the guesswork and minimize the chances of causing collateral damage to the engine..
also allows you to orient the plug wire arrangement to stock location or wherever is convenient for you..
good luck!
Old 10-29-2017, 08:23 PM   #11
kwmech
Every revolution of the distributor or the camshaft. The crankshaft will go around 2 times. #1 cylinder and #6 cyl are "companion" cylinders in that the piston is at TDC at the same time with 0 on the balancer, but on a different cycle. Same as 5 and 8, 4 and 7 etc every 90 degrees
Old 10-29-2017, 10:27 PM   #12
70K10Hunter
70K10Hunter's Avatar
winner.
70K10Hunter is offline   Reply With Quote
Old 10-29-2017, 11:33 PM   #13
Gixx
So, did ya get it fixed ? What worked ?
Old 10-30-2017, 10:13 AM   #14
cadillac_al
OK after re-reading this I see it is a simple 180 out situation. I didn't think the dist would turn enough for the engine to run being 180 off. Simple fix, rookie mistake, we all did it in our younger days.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
