But Found Her 25yrs Later!
Re: Pictures of Rear bag Set keeping stock trailing arms please!!!!
Copy this whole string without the quotes " " :
" Trailing arms bags site:67-72chevytrucks.com " Then paste it in your address bar. Then across the top menu you should see a choice for images.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 10-30-2017 at 09:54 PM. |
Just keep searching you will find something.
thanks guys found what I needed through the first reply, sucks that some thread pictures are blocked by photo bucket now though
I found that if you click on the blocked picture it takes you to the actual picture on photobucket.
Goto my build page, I got start to now. Click link. Here shot of bag set up from ride tech, used same set up from stock to PB arms. Top cup takes two bolt to single all thread and spins on and hole for line. Couple flat plates.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
