10-29-2017, 11:45 AM | #1 |
205 Transfer Case
I have a 1979 Chevrolet 3/4 ton with a 350 and I'm working on a 205 transfer case and I wanted to know the following.....
On the rear output shaft should there be any slack in it because in my case, both the transmission and transfer case I can grab the shaft and pull it in and out about a 1/4 of an inch...is that good or does it mean the bearing has gone bad? I have watched countless youtube videos and what not, but sure could use answer to this so I know what to do next (as far as part ordering and tools). Thanks |
10-29-2017, 02:56 PM | #2 |
Re: 205 Transfer Case
I don't think that's a good sign.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
10-29-2017, 07:14 PM | #3 |
Does that mean the bearing is bad or the transfer case is bad?
Posted via Mobile Device |
10-29-2017, 08:14 PM | #4 |
Zero play on the output of the T-case. Very minimal play on the trans like 10-15 thou.
10-30-2017, 07:47 AM | #5 |
is it a fixed yoke or slip splines ? the fixed yoke has a big nut on it that will work loose over the years torque it at 125pds then check in and out play ..if it is a slip yoke the bearing my be wearing some
4x4k30 if trouble was money i would have plenty |
10-30-2017, 09:46 PM | #6 |
Let me be more specific.....
On the rear bearing, on the main shaft of the tranny, I had mentioned earlier that I could grab the shaft and move it in and out. So I went out this afternoon and I took the lock washer & the nut and I was able to pull the bearing out/off with my hand without resistance. I did not need a bearing puller. So again, is the bearing bad or the tranny bad? Posted via Mobile Device |
10-30-2017, 10:00 PM | #7 |
half the 205 cases i have stripped for parts or rebuilt the rear tail shaft roller bearing drops out or just a little drag . never a puller used .
there a stupid easy case to go threw and freshen up or master bearing over haul kit them . i had never done any t-case years ago and dove in to a 205 and was surprised how easy they are to play with .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
