![]() Join Date: Feb 2009
Original lock nuts - Trivial
Took me long enough to realize there's such an animal as lock nuts on our trucks. I've seen them for other applications, but never realized what they were.
For example, the assembly manual shows lock washers for the Idler Arm Support. Both of my trucks don't have them, and use lock nuts instead. The Tie Rod clamps use them as well. Assuming I'm on track, you can tell a lock nut by the "tapered" head, and finger tight ends where the threads meet the head. Just wondering, what are these called other than lock nuts? Searching for nut types, they don't seem to come up. http://www.mikesenese.com/DOIT/2011/...s-and-washers/
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Re: Original lock nuts - Trivial
At GM we call them "prevailing torque" lock nuts; I see that the McMaster Carr catalog calls them "distorted thread" locking nuts.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#3 | |
Who Changed This?
![]() Join Date: Jan 2013
For applications where high heat (such as exhaust manifolds) one can use nuts with nylon inserts. The modern replacement for that is Loc-Tite(R).
Active Member
![]() Join Date: Jun 2016
Can you reuse lock nuts? There's a bunch that I've taken off but I thought I read it's not good to rease them.
David Larsen 1970 Chevrolet C-10 |
Who Changed This?
If they develop a good running torque, you should be able to reuse them. But if they don't fight you going down, throw 'em out and get new ones.
I once heard that about lock washers. I figured it might be you're just as well to replace them. I think what Steveedee makes sense.
![]() Join Date: Jul 2009
its called a stover nut
#10 | |
The "slice" is just a function of how they are made, basically in a coil which is cut once per rev (like a slinky cut into pieces). K
#11 | |
Interesting write-up on split lock washers, etc. I never could understand why split washers work. According to this they don't: https://engineerdog.com/2015/01/11/1...out-fasteners/
![]() Join Date: Mar 2003
I think Rockford calls them a Type C nut I guess the C is for crimp
![]() Join Date: Feb 2000
We also call them 'prevailing torque' nuts here at Deere. This is a great website for about anything you need to know about locknuts.
http://locknutwhisperer.blogspot.com/
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
google NY-LOCK
Stan 67 swb BLU MULE posted via flip-fone |
#15 |
Actually I dont think you can. There used to be three different colours representing three levels of resistance to heat. I dont know of any that resisted heat that an exhuaste manifold experiences. Not in avaiation industry anyhow. but thats a mute point because the chinese flooded the market with nuts with nylon inserts of many different colours and now you cant tell what your buying. Vendors can make all types of claims but unless they are the manufacturer, there is no telling what is what. But you can get them in a veriety of neat colours to match whats under your hood
#16 |
Couple of additional spots that use lock nuts:
Found a few more: Push rod to brake pedal assm. Combination prop. valve to its bracket. Master Cyl to brake booster studs. Brake booster studs to brake booster brackets. Potentially the clutch fan. Mine just had regular nuts on it, which is wrong. Book calls for lock washers and nuts. With the nylon lock nut business, from what little I've read you don't want to use those with high heat. If I remember right, the exhaust to manifold nuts are brass. They may be distorted thread.......... I only know enough to be dangerous, but I wouldn't use a nylon nut for anything outside light applications.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-04-2017 at 07:34 PM. |
#17 |
Who Changed This?
Yes, the double nuts on the parking brake adjustment are for locking. Exhaust pipe to manifold nuts are steel. And no, don't use nylon locking nuts on the exhaust. The nylon just runs out when the exhaust gets hot enough.
#18 |
Ah, "brass colored" steel. Probably yellow zinc.
