Old 04-19-2004, 12:14 PM   #1
beeroh
need advice on how to remove springs
my delima is how do I lift the frame safely to remove the springs in the rear and front. The frame is about 32inches on its lowest point. Any recomendations on how to lift the frame?
beeroh is offline   Reply With Quote
Old 04-19-2004, 08:55 PM   #2
cdowns
cdowns's Avatar
Forklift???
Old 04-19-2004, 09:59 PM   #3
beeroh
no one rents those around here
84 Silverado,
Old 04-20-2004, 02:33 AM   #4
lost wages
lost wages's Avatar
we built custom jack stands for my buddies truck, he has about 14 inches of lift with 39 inch tires, we also put smaller tires on it when it goes in the shop which lowers it quite abit.
lost wages is offline   Reply With Quote
Old 04-20-2004, 01:56 PM   #5
ryanroo
ryanroo's Avatar
when i lifted my truckwe used a bumper jack and some 20 ton jack stands. you could probably use a cherry picker on the back but i think the front would be to heavy.
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-20-2004, 09:23 PM   #6
beeroh
would removing both tires in the back lowering the frame on to 3 ton jack stands sitting on top of two cinderblocks work?
84 Silverado,
Old 04-21-2004, 05:53 AM   #7
lost wages
lost wages's Avatar
fug no, cinder blocks are weak, why not get some steel and build bigger jack stands. put a jack under the axle, lift it off the ground, take off the tires, lower the jack till you can put jack stands under, youll need the jack under the axle any way to relieve the pressure off the springs from all the weight hanging down. Dont use cinder blocks, you can break a cinder block by dropping it, you wanna crawl under a 5000 pound truck held up by these?
Old 04-21-2004, 06:39 AM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Pic please. I recommend jacking up the front or rear and removing the tires then get some tall jack stands under the frame. 32" to the bottom of the frame that's tall. Do one end first.
http://67-72chevytrucks.com/vboard/s...threadid=97507
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 04-21-2004, 11:23 AM   #9
beeroh
yup, thats what I was thinking, Thanks everyone
84 Silverado,
