Air Vents
My 86 swb has AC and no vents in the kick panels. Can the kick panel trims be changed to make the vents functional or are they not there on my cab?
1986 Custom Deluxe 10 1978 Caprice 2 door - sold 1937 Chevrolet 2 door sedan - project |
![]() Join Date: Oct 2014
Re: Air Vents
There are no air vents down there for the AC
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
Re: Air Vents
Actually, there is one on the passenger side. You can swap out the trim and fabricate a 'pull' to open and close it. It is vacuum actuated when you have A/C, but can be changed to manual with a little custom work.
I wish they would have included those in all trucks, A/C or not!
1976 K20, 292 Straight 6, Turbo 400 1984 K20, 350, SM465 1986 C20, 350, Turbo 400 |
#4 | |
Re: Air Vents
Pics of said vent? Not sure what you're talking about. |
Re: Air Vents
I believe they are discussing the fresh air vent that's built into the wall on the passenger side kickpanel, not the vents that heat/air come through.
Re: Air Vents
I don't have pics. But;
If you look just below the glovebox on a squarebody truck, there is a half dome shaped plastic trim piece, attached to the upper portion of the kickpanel and colored like your door panels. Behind that is a vacuum actuated air vent. When you put your A/C control on "Vent" it routes air from the cowl, through this vent into your A/C ducts. This can be bypassed and made into a manual vent if you no longer have A/C or choose to get rid of it for whatever reason. Lets more air in than you might think. Non-A/C trucks have them on both sides from the factory.
Re: Air Vents
Can't believe I'm saying this, but I'm glad my truck doesn't have A/C. I love my kick panel vents! One day I may add vintage air, but the vents are staying!
This actually explains why my buddies truck doesn't have them. We couldn't figure out why it didn't. Too bad too since the previous owner took off all the A/C stuff under the hood.
1978 GMC K25 1984 Chevy Scottsdale K10 built 350 4"lift - SOLD |
#8 | |
Re: Air Vents
Re: Air Vents
It's the right side kick panel. Here's a pic, top left in the photo. The kick panel with the opening.
Re: Air Vents
I actually cut the opening out on the drivers side on an AC cab and put the old style "floor" vent in. It was a little tedious but it was worth it. there was actually a stamped area there for a template.
Re: Air Vents
Gotcha. My truck has A/C which, of course, doesn't work. I've wondered what was under the little dome, but haven't ever looked.
I've got to tear into my entire system. The temp lever only goes about 2/3 of the way to cold before it stops, and my airflow doesn't seem to switch to the proper vents when I switch from vent to heat to defrost. |
Re: Air Vents
Yep fresh air vent is what I meant. Thanks guys
#13 | |
Re: Air Vents
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
