11-02-2017, 08:59 AM | #1 |
Distributors, HEI vs standard point type
My '72 350/175 has had the distributor changed to the HEI type. Would like to install a factory tach, is there a different tach for HEI vs standard point type distributors ?
11-02-2017, 01:18 PM | #2 |
Msgt USAF Ret
Re: Distributors, HEI vs standard point type
Well there's pertronix and a few others and then there's this one.
If you don't mind foreign made. https://www.ebay.com/itm/SBC-BBC-CHE...MAAOSwaB5Xvd2O
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-02-2017, 03:49 PM | #3 |
Im told that the HEI distributor came out in '75, prior to that they had the common or standard distributor with points and a separate coil, the HEI has a coil on top of the distributor, Ive been told that the HEI distributor could be inst'd on the '72 350/175 by removing the stock distributor and inst the HEI thus eliminating the points system, IS THIS CORRECT ? Also could I use the factory tach that would have come with the common or standard distributor with points ? IS THE TACH THE SAME FOR BOTH DISTRIBUTORS ?
11-02-2017, 04:12 PM | #4 | |
11-02-2017, 04:12 PM | #5 |
Upgrading to HEI is a common thing on our trucks ! Installing a GM HEI is a simple plug and play with one exception, running a dedicated 12V power supply. The factory tachometer was designed to work with standard points distributor
71 C-20 07 Magnum RT AWD |
11-02-2017, 08:22 PM | #6 |
Over the years I have owned about 5-6 trucks that either had factory tachs in them or I installed a tach dash. Every single truck I had installed an HEI and changed out the end on the wire and plugged it in. Never once did I have a problem with the tach or distributor
11-04-2017, 06:13 PM | #7 |
When I went to HEI, my tach lasted about 10 seconds before dying, even with the reducer installed, I just have one bolted to the column now until I can upgrade the dash.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
