Old 10-28-2017, 10:32 PM   #2176
jeh
jeh's Avatar
Re: Crusty Rusty Leaky Squeaky 67 Step
I just got caught back up on your build Vic, looking good!!! A lot of work has been done since I checked in last
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 10-30-2017, 12:37 PM   #2177
sduckworth13
sduckworth13's Avatar
I'm always glad to lend a hand Vic.
Scott
sduckworth13 is offline   Reply With Quote
Old 11-01-2017, 11:53 PM   #2178
jlsanborn
jlsanborn's Avatar
More amazing detail! Can't wait to follow all this wire you need to sort out and hide.
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 11-05-2017, 08:30 PM   #2179
Vic1947
Vic1947's Avatar
The wiring is turning out to be a bit formidable. Integrating the stock wiring harness with non stock gauges, heater/AC, engine and trans, cruise and all the other gizmos I want to run makes my noggin ache. Add to that the 10 lb of sh*t in a 5 lb bag factor. I'm making progress (slowly) but it looks like I'm going to have to cave in and contact a few vendors to get some advice.
The push button start I bought back in Nov 2013 came with remote keyless entry. The one piece side windows relocated the window channel and I really don't have the real estate for power locks. So I need to separate the wiring harness for the two boxes (start and locks) into just one. Also, there are at least three devices that want to control the cooling fans. The ECU, the built in fan controller and the Vintage Air. Plus, after all this time, it turns out my stereo head unit has independent front, rear and subwoofer preamp out connections. Of course, the amp uses a single input with crossovers to drive all the speakers.
I'd really like to make all this work without additional expenditures. I once worked for a guy that reminded me regularly that "anyone can smother a fire with money."
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 11-05-2017, 09:36 PM   #2180
builtbyKane
builtbyKane's Avatar
I am not looking forward to this in the coming months. Yours is looking great though.
builtbyKane is offline   Reply With Quote
Old 11-06-2017, 10:01 AM   #2181
knomadd
knomadd's Avatar
Oh man.... I remember all of that wiring, confusion and months of planning to integrate the existing wiring, the LS wiring and the new items I added. That was a lot of "fun". That's exactly whey I never installed my viper alarm/remote start I bought almost 2 years ago. So many things to add and figure out... I couldn't wrap my brain around it all.
I wish you luck, Vic.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 11-06-2017, 11:15 PM   #2182
swamp rat
swamp rat's Avatar
I don't envy you on this one....
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-10-2017, 07:01 PM   #2183
Vic1947
Vic1947's Avatar
I share everyone's dread where it comes to wiring. Seems like I have to relearn everything when I get into this part of the project.
I made a small box that fits in what's left of the glove compartment to house some of the modules that aren't suited for stashing in the console. I modified the wiring harnesses for the push button start module and the encryption module that goes with it. Brian Wen (tech support at Advanced Keys) was very helpful and sent me a couple of diagrams marked with the relevant connections. I think I have everything spliced the way it should be.
Also mounted in the box is the DBW cruise control from HotRod Therapy. I opted for the dash controls instead of the turn signal controls. The column is a bear to disassemble and I've probably already used up my quota of good luck getting it back together the first time without breaking anything. The last module in there is the Sirius/XM module for the stereo. I plan to route the wires for the Sirius/XM and GPS antennae thru a small hole in the dash above the box. There's enough wire to mount them on the rear bumper if I wanted to, but they can't be spliced, so I'll just have to bundle the excess.
I also received the Pioneer secondary amp for the stereo today so I'll have to figure out a spot for it. I think the panel behind the passenger seat is too full for it, so it will likely end up behind the driver seat.
More to come...
Victor
Old 11-10-2017, 07:11 PM   #2184
knomadd
knomadd's Avatar
With the work you've done so far, I have no doubt you'll get the wiring taken care of and make it look good too. Just be patient and if you get confused or frustrated, walk away for a bit. I've had to walk away for a week a couple of times, just to give my brain and nerves a break. I'm not sure how much help I can offer, but feel free to ask if you have a question. I might have an answer or be able to point you in a direction to find an answer.
-Duane
Old 11-10-2017, 08:51 PM   #2185
builtbyKane
I just ordered my Advanced Key push button start system last week. I may hit you up for questions if I get confused. Your wiring is looking extremely clean and organized. Random organized wiring pictures really get me pumped to work on mine for some reason.
Old 11-12-2017, 11:48 AM   #2186
jlsanborn
jlsanborn's Avatar
Oooh boy! That looks like a challenge but you will kill it. I have little patience for automotive wiring and the goofy block diagrams.
Old 11-12-2017, 01:02 PM   #2187
Trackman101
Trackman101's Avatar
The extensive planning and detail that has gone into this build is amazing.
Trackman101 is offline   Reply With Quote
Old 11-14-2017, 08:06 PM   #2188
Vic1947
Vic1947's Avatar
Thanks, Duane, took your advice and worked on something else for a while. Helps greatly!
I'd be glad to share any and all info I've assembled on this. The instruction book made a lot more sense after I got a couple of diagrams from their tech support. Most of the features are optional and my setup ended up being pretty simple.
I know it, John! What kills me is how wires go into a box one color and come out another. Dang!
Thanks! However, as others can attest, it's drifted a long way from the original plan.
Taking Duane's advice, I hung the doors and installed a few interior parts instead of working on wiring the last couple of days. The aftermarket door handles gave me fits. The angle of the threaded holes didn't line up with the reinforcing plates on the inside of the door skin. I ended up using fender washers and socket head cap screws to make it work. Also wasn't able to use the rubber gaskets that go between the skin and the handle. Clear RTV was my sealant of choice. Hope I never have to remove the handles.
My painter called and the bed is finished. He offered to redo the front inner fenderwells, front and rear bumpers and a few other pieces for me. Decided to change color on some of the parts and it's too cold and crowded for paint work here at the house.
Victor
Old 11-15-2017, 04:50 PM   #2189
Low Elco
Coming together! I gotta swing by and see in person one of these days. Call if you need help with the bed, or a trailer.
Low Elco is offline   Reply With Quote
Old 11-16-2017, 12:56 PM   #2190
sduckworth13
Awesome to hear it's all painted now! Looking good Vic!
Scott
Old 11-16-2017, 01:08 PM   #2191
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
It's coming together and looking awesome.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 11-16-2017, 06:55 PM   #2192
swamp rat
swamp rat's Avatar
Can ya do my truck next? Lol! Looks great!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-16-2017, 06:57 PM   #2193
swamp rat
swamp rat's Avatar
I don't remember if that's a 67 but the 67 only had a different angle to the door handle screws.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-17-2017, 08:59 AM   #2194
Bennett68C10
Bennett68C10's Avatar
Looking good Vic!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 11-17-2017, 09:32 AM   #2195
Elliot949
Elliot949's Avatar
Looking Great Vic... Looks like you are getting pretty close to firing that thing up...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 11-21-2017, 07:52 PM   #2196
Vic1947
Vic1947's Avatar
Anytime, Chip. I appreciate the offer, but all I have left to bring home will fit in the car.
Thanks, Scott, although it's not quite complete. I took the inner fenders, bumpers and a few other parts to Justin when I picked up the bed and asked him to do a color change on them. Bumpers will now be body color which should look a little more integrated.
It is a 67 with stock doors, Mike. I've never heard that about the handles but it sure lines up with what I experienced. I didn't research it a bunch when I bought the repro handles. Of course, the catalogs I have list one part number per side for 67-72. Nothing special for the 67.
Originally Posted by Bennett68C10 View Post
Looking good Vic!
Thanks, Keith!
If I got off my duff and really worked at it, I could probably have it going in a few weeks, Dan. But I seem to be in slow mo mode these days.
The bed turned out pretty nice. He did the bedliner exactly like I wanted and it looks like it was done by Line-X. The tailgate has some orange peel on it in the recessed area, but he offered to go back over the entire truck after it's fully assembled, so I may take him up on that. Everything is covered with buffing dust right now, so the photos aren't the best. The gaskets for the reproduction tail lights are too short and will have to be cut and spliced to properly seal the lens, but that's no biggie. Just gotta keep on trudging.
Victor
Old 11-22-2017, 12:50 AM   #2197
Xeen
Xeen's Avatar
Oh this is exciting, everything is coming together.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 11-22-2017, 01:27 AM   #2198
Ol Blue K20
It's gonna be bad @$$. Looking forward to it!!
Dale
Old 11-22-2017, 03:37 PM   #2199
knomadd
knomadd's Avatar
Looking good Vic!
-Duane
Old 11-25-2017, 07:14 PM   #2200
Vic1947
Vic1947's Avatar
Thanks, guys! Bit of a milestone today, the bed is back on the chassis. Only one minor hiccup. The Boyd's tank has two bungs in the top, a 1/2 NPT near the fill neck and a 3/8 NPT further forward. I plumbed the vent hose into the one closest to the fill neck and when the bed was almost down, it hit the cross rail. So I took it back out, put the plastic plug back in it and removed the plug from the front. Plenty of room to install a 3/8 90 fitting in it and attach the hose. It's still sitting really high as I've left it in the top setting for the bags which makes it a lot easier to work on. But pretty soon it will be down where it belongs.
Victor
