Old 11-08-2017, 06:32 PM   #1
BCOWANWHEELS
Proportioning valve question
I,am doing a power drum brake conversion on my 70 c10 and was wodering if the porportioning valve is the same for manuel brakes as power brakes. All help is appreciated
thanks
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 11-08-2017, 07:20 PM   #2
demian5
demian5's Avatar
Re: Proportioning valve question
Yes
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 11-08-2017, 08:33 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
Note that power brakes systems have different wheel cylinders and master cylinders (the bores are different sizes). Are you changing those over at the same time?
~Steven
Simi Valley, CA
Old 11-08-2017, 09:14 PM   #4
BCOWANWHEELS
Yes, doing 100 per cent brake job. ALL THAT IS OFFERED FOR WHEEL CYLINDERS IS STD AND FOR THE H/D BIG SHOE BRAKES
Old 11-09-2017, 08:13 AM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Proportioning valve question
My understanding of the proportioning valve is it's only used for disc brakes and drums together not for both drums.
Google:
A proportioning valve is a valve that relies on the statics to supply a reduced pressure to an output line. A simple example is where spring load applies a reducing force so that the output pressure is reduced. Proportioning valves are frequently used in cars to reduce the brake fluid pressure to the rear brakes.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-09-2017, 09:13 AM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Drum brake trucks have a distribution block.
The 71-87 disc brake trucks have a proportion valve.
Just add the brake booster to your current M/C.
Done.
Keith
Convert to disc brakes.
Old 11-09-2017, 11:49 AM   #7
BCOWANWHEELS
thanks fellas
Old 11-09-2017, 11:59 AM   #8
hamjet
hamjet's Avatar
I'm following this one, let us know how and what you end up doing, I plan on doing the same, Joe..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 11-09-2017, 01:08 PM   #9
demian5
demian5's Avatar
Yes - The thing already on your truck that is installed between the master cylinder and the wheels, that the brake lines go into and out of, can be reused for your power brake conversion.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 11-09-2017, 06:08 PM   #10
BCOWANWHEELS
I,am just going to reinstall it like it was except with a booster
Old 11-09-2017, 07:10 PM   #11
painterljp
That's what we did on our 68 it works find. A lot improvement over no booster. Powered the drums brakes. We left the original valve in place. Brakes work a lot better.
painterljp is offline   Reply With Quote
Old 11-09-2017, 08:22 PM   #12
Andy4639
Old member
Andy4639's Avatar
That's what I did on the ramp truck.
Old 11-09-2017, 08:41 PM   #13
hamjet
hamjet's Avatar
Not to hijack the thread but are those booster brackets hard to come by?
Thanks, Joe..
Old 11-09-2017, 08:44 PM   #14
jocko
jocko's Avatar
Usually an easy pick from one of the many truck being parted on the parts board. Sometimes sellers prefer to sell with the booster which adds weight and cost, but understandable if all is in good condition. Captainfab also sells a custom one that tucks in closer to the firewall - but it may require some thinking as far as the pushrod arrangement - ask the good Captain, he will know exactly what you need. But if you want original, a truck being parted or a WTB ad would produce results rather quickly I'd imagine.
Old 11-09-2017, 11:06 PM   #15
BCOWANWHEELS
Andy4639 , did you use any booster support braces
Old 11-10-2017, 07:01 AM   #16
Andy4639
Old member
Andy4639's Avatar
Talking Re: Proportioning valve question
No what you see is all I used. The truck that I got it off of didn't have them either.
My 71 factory setup doesn't have it either.
The block on the master cylinder is just a distribution block & brake light hookup and not a porportioning valve.
Disc to disc and drum to drum don't need them.
Old 12-11-2017, 01:51 PM   #17
Gregski
Gregski's Avatar
Done.
Thanks, do the 71-87 trucks with proportioning valves still run the brown wire to the brake idiot light in the gauge cluster and the proportioning valve?
I have a basket case '71 GMC (it's a '71 cab on a '69 chassis) hence my question
Gregski is offline   Reply With Quote
Old 12-11-2017, 03:18 PM   #18
jocko
jocko's Avatar
71-72 do, can’t speak for 73 and up definitively.
Old 12-11-2017, 05:57 PM   #19
MattPSU
MattPSU's Avatar
HEY! That looks familiar! Genuine LowLion parts on the Ramp Rat!
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 03-02-2018, 10:51 AM   #20
daveinluray
daveinluray's Avatar
a bit old but as i search this thread is most recent. I am finding that the valve in question is called a combination valve(per service manual). this seems to indicate that this is another name for proportioning valve?
Please correct any thinking here as I am trying to get my head around doing my brakes correctly and safely.
It is my understanding that with front disc and rear drums the front need to be limited until the rear brake can overcome the pull back springs.
my truck is missing its valve and I have purchased one online new. Problem is it has an extra port (two) for the front. Can I plug one or should I get a different combination/metering valve?
1972 GMC 157" dump
daveinluray is offline   Reply With Quote
Old 03-02-2018, 11:24 AM   #21
Gregski
Gregski's Avatar
it may be Combination Valve for drum brakes, Proportioning Valve for disc brakes. Jump on AutoZone's website or RockAuto and see if they sell both for say the 1971 model year, just an idea.
Old 03-02-2018, 11:45 AM   #22
daveinluray
thanks. I bought what was listed specific for my model(front disc rear drums) everything i found was for two front lines. I hate to buy used because it sounds like they are a pain to reset if tripped.
I am OK running two front lines but would be happier to leave all as is, if possible, and just add a combination valve.
1972 GMC 157" dump
Old 03-02-2018, 03:46 PM   #23
RichardJ
I don't understand why the English language is such a challenge for some on this board. Actually, not just this board, but throughout the automotive world.
com·bi·na·tion
/ˌkämbəˈnāSH(ə)n/
noun: combination; plural noun: combinations
1. a joining or merging of different parts or qualities in which the component elements are individually distinct.
"a combination of blackberries, raspberries, and rhubarb"
An automotive COMBINATION VALVE is THREE valves COMBINED into ONE unit. It is comprised of a Metering Valve, a Pressure Differential Switch and a Proportion Valve. Each of those three items serve different functions.
A Pressure Differential Switch that Andy showed you is a stand alone unit, that turns on the dash warning light and nothing else.
A Pressure Differential Switch in some form, is used on dual brake systems with drum/drum and disc/drum and disc/disc. It is used with power and non-power systems.
The first picture is a Combination Valve.
The second picture is the exact same thing, but as three individual units. This requires a lot of plumbing.
'67 GMC 2500, 292, 4spd, AC
RichardJ is online now   Reply With Quote
Old 03-02-2018, 06:42 PM   #24
daveinluray
com·bi·na·tion
/ˌkämbəˈnāSH(ə)n/
you missed a part but thanks for trying
"my truck is missing its combination valve(service manuals words not mine) and I have purchased one online new. Problem is it has an extra port (two) for the front. Can I plug one or should I get a different combination/metering valve?"
i will search further this evening for a better match when time is available but thought someone might have a quick answer to the outlets in question. but thanks anyways.so far they all come up with a valve that appears to separate outlets to the front brakes. but my math is simple too so i could be wrong.
1972 GMC 157" dump
Old 03-02-2018, 07:29 PM   #25
ray_mcavoy
The OE style combination valves have 2 front outlets that are typically plumbed directly to the left & right front calipers. But the front brake line plumbing in 71 & 72 trucks includes an inline Tee fitting so only one front outlet is needed. You can safely plug the other unused front outlet with an inverted flare plug. In fact, I believe the factory installation used a plug (rather than a special single-outlet combo valve) for the 71 & 72 trucks.
ray_mcavoy is offline   Reply With Quote
