#101 | |
Re: #the 77_remix
#102 | |
Happy to be here
![]() Join Date: Mar 2000
Re: #the 77_remix
They do have an X-act fit dash control, but it hasn't made it to the website. It's listed on Instagram here-Link It can be controlled by an app as well. Restomod offers a unique product with their Membrane sound deadner. It is the only true sound dampening material with a built in thermal insulation. I look forward to installing the product and posting reviews.
#103 |
Happy to be here
Re: #the 77_remix
Scoti is correct, I am running a Ramjet 350. It's a fuel injected GM crate motor that was installed by Roger at RPL Custom a few years back. It's still a great motor and stands out in today's ocean of LS conversion. It will stay, but a fresh look is on the way.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-12-2017 at 12:12 PM. |
#104 |
Re: #the 77_remix (Elwood)
Now that SEMA is over, any chance of us finding out which wheels have made the cut?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#105 | |
Happy to be here
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-13-2017 at 12:56 AM. |
#106 |
I was really hoping that you would have convinced them to build some 22" Gassers so I could put them on the back of my Blazer.
#107 |
Happy to be here
Saturday I spent the day at my brother in laws garage. He has a really nice 66 Fairlane with a 390 backed by a C6. Last year he had some internal issues so he decided it was time for a rebuild. He had Nickens Racing build a mild street motor with a few upgrades.
It was finally time to install it so Chris and I went to assist. That turned in to an all day deal. Many years ago I helped a buddy stab a 351 in a 69 Mustang. We fought the manifolds against the shock towers but finally wedged it in place. This all came back to me yesterday while trying to squeeze a 390 with Tri-Y headers in between those same style of shock towers on this Fairlane. It will fit, but plenty of paint was scratched in the process.
#108 |
Happy to be here
Since Saturday was "Fun Ford" day it was time to get back on Elwood. With the gas tank previously pulled it exposed the bottom of the cab, and it wasnt pretty. I have detailed the bottom of this truck several times, but never had a reason to pull the tank. Yuck!
I started with the frame rails and worked my way forward. With them sanded smooth, it was time to clean up the cab. I worked across the floor and down the rockers. The good news is all the grunge had created a nice protective barrier, and there was almost no rust. You can see a couple of spots that were chaffed and some surface rust had started. I sanded it raw and treated it with Rust-Mort. I followed that with a couple of coats of satin black. This will be top coated with rubberized undercoating to seal it permanently.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-13-2017 at 09:53 PM. |
#109 |
I'm just glad to be here!
Nice progress. How did you come up with the name Elwood. I like it!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#110 | |
Happy to be here
My wife and I decided that the 77 needed a name. It had always been "The 77" so it was hard to make a change. We had a long list of options but none seemed to stick. Recently I was discussing it with my friend Mike and he suggested Elwood. Even though it was on our original list, it wasnt until someone else suggested it that it really sounded right. With the addition of the woodgrain, Elwood was a perfect match. I'm waiting for Joseph from EDL to get caught up so he can update my rendering. Until then, heres what Elwood will look like when done.
#111 |
Happy to be here
Re: Elwood the 77_remix
Monday was a a busy day at work. I managed a bit of shop time as the push continues to get the rear done. My mission was to get the drivers side floor pan was sanded and painted. I had to drop the Ridetech Suspension #bigred valves down to gain access. They will be moved forward a bit to make space.
After an hour of sanding and cleaning, I wiped with brake cleaner and topped it with satin black. Later I will spray it with undercoat.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-14-2017 at 03:10 PM. |
#112 |
Happy to be here
I had been asked not to release any pre-production pics of the wheel I plan to use on Elwood. Now that American Racing has released the VF526 for production, I can share. It was an honor to work with Carter Hickman in the early stages of the design process. He is an incredible digital artist and has great vision.
American Racing liked the concept but it took several months to go through the necessary steps for production approval. With that process cleared, and a custom set rushed through production, they made their debut at SEMA 2017 on a build by KC Mathieu. I feel this style will be right at home on my 77 Cheyenne.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-15-2017 at 11:29 AM. |
#113 |
Those are pretty cool, what color will you be using on the wheels?
#114 | |
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
#115 | |
Happy to be here
#116 |
Happy to be here
I have been mapping out my exhaust system while working under the truck. Due to space limitation from the RideTech 4 link and air tanks, I cant route true duals. Consequently, I plan to utilize some of the existing pipe and update the components.
My existing system starts at the motor with 2.5" Corvette ramhorn manifolds that have been polished and ceramic coated. From there I have a 2.5" mandrel bend Y pipe that went to a high flow cat. Thats followed by a SI/SO Flowmaster muffler.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-16-2017 at 11:20 AM. |
#117 |
Happy to be here
I had the cat installed when I RPL did the system to pass a visual test for state inspection years ago. Its no longer necessary or functional, so it goes away. The Flowmaster has rusted out from the inside, so its scrap as well. We used flanges to make the system serviceable which was great at that time.
Yesterday I spoke with Kevin Deeds from Deeds Engineering and explained what I had in mind. He offered his advice and agreed to send me a box of goodies to work with. If you have ever considered V band components take a look at what Kevin offers. The bands and related hangers are truly a work of art.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-16-2017 at 11:34 AM. |
#118 |
Happy to be here
I plan to replace the flanges with V bands, and add Deeds hangers where needed. The hangers give some flex, but its minimal. To compensate I will utilize a Vibrant Performance flex coupling t the end of the Y pipe.
Im undecided on a muffler yet. I have Borla XL on Scarlett and like the sound. I'm looking for something that sounds good but not loud, and doesnt resonate. If you have any suggestions let me know.
#119 |
Nice updates. I really like the wheels too. Its still hard to not picture this truck without Vintec Wheels...But the new wheels should be spot on along with all the updates you are doing!
#120 | |
85 Silverado - 350/700r4 Last edited by N2TRUX; 11-17-2017 at 11:02 AM. |
#121 |
Happy to be here
I know, right. Those VinTechs are timeless, but i feel like these will look even better.
#122 |
Happy to be here
My buddy Keith says the same thing. What series/model are you using?
#123 |
I have 2 - 12577 on mine. Love them.
85 Silverado - 350/700r4 |
#124 |
Happy to be here
Yesterday I got some nude photos from Brent at Sculpt Garage. No, I haven't switched teams, he was showing me that the seat foam in my stock bench still looks great. He plans to layer it with fresh foam to give some depth to the inserts, but the core of it is still functional.
Brent received a shipment from Chris at Snowden Supply with a few yards of Enduratex "Oxen" vinyl inside. He will be starting the seat rebuild this week.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-17-2017 at 12:30 PM. |
#125 |
Junior Member
I like the new wheels so much I think I need a pair for my new to me 83. Any idea when they can be purchased and price point.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
