07-30-2009, 09:42 AM | #26 | |
Re: ls1 swap question fuel tanks
Here is a copy from the 87 Factory Wiring Manual , It shows the wire you are talking about (circuit 490) is a switching wire back to the relay and then conects to the "ECM" (engine computer). I will include the wiring to the "Tank Switching Valve" which show the circuit back to the sender/Fuel Pump I know these diagrams can be hard to follow , take your time and follow the circuit number. Hope this helps you out... Desert |
07-30-2009, 09:53 AM | #27 |
does that mean to get the switching valve for '87 sending units to work i'll need the ecm for an '87 also?
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list Last edited by menace121978; 07-30-2009 at 09:54 AM. |
07-30-2009, 09:54 AM | #28 |
Next project: 1970 K10
So if I am following this correctly here, the switching wire in the 2006 harness from the PCM would take the place of the red wire (circuit 490) at the OEM relay?
Usually, when these harnesses and reworked, the fuel pump switching wire from the PCM is wired in to a relay, then from there you are to connect it from that relay to the pump. So it looks like I would remove the relay from the reworked 2006 harness (or just not have them install it) and hook that switching wire to the original relay on the firewall. Thanks for the drawings! The middle one is hard to read though, I'll see if I can blow it up a little.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
07-30-2009, 10:01 AM | #29 | |
If you do the LS swap, that PCM will have the switching wire (that signals the relay to turn on) already in the harness. But you would need to configure your truck harness to turn on the proper pump for whatever tank you switch to. You could ether do it using the schematics above, or just get the wiring from an 87 donor truck.
07-30-2009, 10:11 AM | #30 |
i understand. i didnt think the new ls harness would have a switching wire for some reason... so i'll need an '87 harness that goes from the plug in the firewall to the sending units to the switching valve. that would probably be the cleanest way rather than wiring the pumps myself?
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
07-30-2009, 10:17 AM | #31 |
Yeah, if you can find a donor that would be the best route.
I don't know if you have this link or not, lots of great LS wiring info! http://www.lt1swap.com/2000harness.htm
07-30-2009, 10:30 AM | #32 |
whoa, thanks for that Bob! that is a good one... saved!!
07-30-2009, 07:03 PM | #33 |
Thanks for the drawings! The middle one is hard to read though, I'll see if I can blow it up a little.[/QUOTE]
If it will help you I can rescan the "ECM" wiring and repost it? Desert |
07-30-2009, 07:08 PM | #34 |
One thing to note on the 87 TBI setup the sending units are plumbed with a return line from the factory.
What would you use for a Fuel Pump in a "TBI" style sending unit? Does a WALBRO pump go high enough to feed an LS1? I know their working pressure is like 5 times what a Throttle Body setup needs. Just trying to get my head around this swap... Desert |
07-30-2009, 07:18 PM | #35 | ||
I'm using ACDelco EP381 pumps. It's what GM recommends in their LS1 swap manual, and is what S&P uses in-house on the swaps they do. Also, I haven't been hearing much good about the Walbro pumps since Walbro sold their pump unit. That, and the Delcos are inexpensive and are readily available at most any parts store.
07-30-2009, 10:47 PM | #36 |
What is the working pressure on your LS1 setup? Do you need to switch it all over to braided lines? or can you use high pressure rubber with good clamps?
Desert |
07-30-2009, 10:59 PM | #37 |
Still gathering parts right now. I've seen people use the high psi line all the way forward, and braided too, but I am going to use the original steel line for the most part. It's there, and it will save $$.
Plus, it's 3/8", I can tap the filter/regulator into it easily along the frame, and it exits up at the engine in a perfect place. And I won't need the return line so I can remove it all together from the engine to the filter/regulator. From there back to the tanks, I will replace all the rubber lines with high psi hose.
07-31-2009, 08:55 AM | #38 |
at least 58 psi. to 60.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list Last edited by menace121978; 08-01-2009 at 05:49 PM. |
01-26-2010, 06:55 PM | #39 |
great thread! thanks all!
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! |
11-09-2017, 01:30 PM | #40 |
Doing an ls swap in an 87, with dual tanks, and a procharger. Anyone know where to find a fuel selector valve that will handle up to 90lbs of pressure?
11-10-2017, 12:54 AM | #41 | |
* Pollak high psi tank selector valve, this is a direct OEM replacement (JC Whitney p/n ZX812705U) $83 * Fuel selector switch from an 87, replaces existing dash switch (AC Delco p/n D7089C) $11.50 at rockauto.com * Corvette filter/regulator if running a returnless/1 line system (WIX p/n 33737) $34 at rockauto.com you will need the Pollack switching vavle
4x4k30 if trouble was money i would have plenty |
11-10-2017, 12:26 PM | #42 |
Ep381 pumps will not produce enough fuel flow/pressure for a procharger. Also read in previous posts that that pollack valve only handls 60 psi???? This would all be great with "stock" LS engine swaps.
11-11-2017, 06:51 PM | #43 |
Does ProCharger actually suggest 90lb fuel pressure? Which kit are you talking about?
11-12-2017, 12:33 PM | #44 |
The person that is going to do the tuning/dyno when the truck is finished suggested 340lph fuel pump supply which produces 90psi. The procharger is a D1SC.
11-12-2017, 02:34 PM | #45 |
Wow-thats some serious fuel pressure!
