Steering Column ????
Does anyone know if you can buy a new steering column for a 63 C10 with a 3 speed on the column
or does anyone a rebuild kit? Thabks,,,, |
Re: Steering Column ????
They don't make new manual columns for out trucks. I replaced mine with a I did it and installed a T5 trans with a floor shifter.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 Last edited by 62 Barnfind; 11-11-2017 at 09:21 AM. |
60-66 Nut
As already said, there is no such thing as a new column for the '60-'66 trucks. You can purchase the individual parts and rebuild your original steering column.
Moderator
![]() ![]() Join Date: Aug 2011
Yep, aftermarket only (like Ididit).
You can use a column out of a 70s truck with a 3 on the tree but the linkage has to be adjusted correctly. It wouldn't be worth the work (my opinion). You would be best to go with a floor shifter and regular column or something like that. There are plenty of options though.
One foot in front of the other
![]() Join Date: Aug 2008
Or you could become a supporting member and that would give you the option to do a Want To Buy post.
hi marcus, that is also my problem I've also 63 c10 I want to change my steering column for new .nobody could tell me how to do it. there is no new to buy.I am happy for idea
gruß from the black forest meinolf |
Here is an option for 73 van tilt, retro fitted into a 64. http://67-72chevytrucks.com/vboard/s...d.php?t=523901
